can't pull codes
Old 03-30-2008, 09:01 PM
poppypizza's Avatar
Default can't pull codes
Cant pull codes, p28 chipped and yeah i have the right connector, anyone know?
Old 03-30-2008, 09:08 PM
MasterShake's Avatar
does the cel on your cluster work?
Old 03-30-2008, 10:28 PM
ek9junky's Avatar
Default Re: (MasterShake)
what year is the car? have you tried to check the bulb in the cluster or even a code reader...autozone lets you borrwo them either obd1 or obd2 they have them for rent!! What method are you using to check your codes? https://honda-tech.com/zerothread/1901557
Old 03-31-2008, 12:08 AM
poppypizza's Avatar
sorry its a eg hatch, yeah the light works, it flashes once and stays on,
Old 04-01-2008, 02:56 PM
your connection sucks
Old 04-02-2008, 12:47 AM
poppypizza's Avatar
...any ideas where, what wires are they to the ecu,, apparently this car has had a piggyback system on it so there are some cut wires.
Old 04-09-2008, 09:39 AM
poppypizza's Avatar
still cant pull them,, even with a different ecu, anyone at all?
Old 04-09-2008, 09:47 AM
civicjoe's Avatar
Default Re: (poppypizza)
I just went through this yesterday. If you have a cel find that jumper and use a wire or pin to do the 'pin trick.' THe cel will flash and tell you what codes you have. If you do the pin trick and the cel is solid (doesn't flash) then you have a connection/hardware issue. Check and make sure EVERYTHING is connected properly. As far as wiring the only thing that I can think of doing is tell you to search the pinouts for your ECU.
Old 04-09-2008, 11:24 AM
H-T White Ops
NOFX's Avatar
If you have a DLC, there is a fuse that protects it under the hood.
Old 04-10-2008, 08:58 PM
poppypizza's Avatar
where is this "DLC" on a eg hatch?
Old 04-10-2008, 09:23 PM
RS-2's Avatar
its the same little pin you jump.
unlike a DLC on the obd2 cars.
if the ecu is solid you have a bad basemap, erase your eeprom, and re burn a map
Old 04-10-2008, 09:38 PM
poppypizza's Avatar
okay running ls vtec and tried a p75 ran the car at a high idle same thing with the cel light
Old 04-13-2008, 07:28 PM
poppypizza's Avatar
anything? anyone?
D16SohcVtec
04-10-2009 09:44 PM
blumpfish
04-20-2006 10:28 AM
beeroh
09-24-2004 08:16 AM
LSpimpTEC
07-29-2004 09:09 PM
fe519
02-24-2004 04:49 PM
Quick Reply: can't pull codes
