Need Help on Changing Gauge Cluster..
in order to change Gauge Cluster.. do i need to take apart whole dash?.. i want to change gauge cluster but dont know how,,, plz help me
Re: Need Help on Changing Gauge Cluster.. (*****yEyez)
At the top of the cluster there are two screws. take them out and pull the bezel toward you. once the bezel is removed there are 4 screws holding the cluster in. romove these and the cluster will come out.
These dircetions are for a 96-2000 civic, any other model I do not know.
Re: Need Help on Changing Gauge Cluster.. (CRITTERMATT)
Thx!! if i buy a cluster with techometer can i hook it up right away even thou i had none in my old one??
Yes it should be plug and play. But dont hold me to it. Everything else should work but you might have to wire the tach up. It doesn't take but a few minutes to find out. It only takes a few minutes to get the cluster out.
Re: Need Help on Changing Gauge Cluster.. (Daniel_san)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel_san »</TD></TR><TR><TD CLASS="quote">don't forget the screw behind the hazard botton
you need to pop it out, to get to the screw</TD></TR></TABLE>
Not for an EK.
He's got both according to the sig.
Not for an EK.
Re: Need Help on Changing Gauge Cluster.. (Ricey McRicerton)
I just got done with a cluster swap in a 92 vx, no tach POS. We swapped in a SiR cluster with a tach and all worked fine, plug'n'play is nice, no wiring needed at all.
It should take less then 30 minutes for this install.
i have a 5spd 00 ex cluster for sale. it has 42k ac technic indiglows (but you can take those off) and a blue bezel
