Big brake kit
Brand New
Re: Big brake kit
Do you really need a bbk? If you're going for looks, I'd just spend that money elsewhere, like an exhaust you mentioned in one of your threads.
If you tracked your car, you really don't need such an upgrade. From a performance perspective, all one needs are good pads and better brake fluid, even stock rotors will suffice.
The only bbk for our cars I know of is the brembo gt kit that ChargedSi's running, these go for 2k+ I believe.
Re: Big brake kit
I seen them on collegehillshonda.com theyre not even that expensive , i been searchin in the dealers around wher i live and theyre way more money than college hills...
Tickle-shits
Re: Big brake kit
Look man, i'll give you a piece of advice, unless you are running 400+hp a BBK is worthless, Earls braded steel lines, powerslot rotors and EBC red stuff pads is just about all you need on the track.
Re: Big brake kit
.. True i realized that,, i think im just gonna rock with the hfp braking system, but im gonna use different pads probably ebc green stuff pads,(thats what i used on the ep3 i had)..
Re: Big brake kit
Unless you'll be tracking your car, I suggest upgrading to stainless steel brake lines, high temp brake fluid and more aggressive brake pads if you want improved braking for your DD. That's it!
Re: Big brake kit
cool thanx , thats what im gonna do and im gonna get the hfp rotors, as far the brake pads , thats what im gonna get the ebc's green stuff theyre pretty good ..(expensive but good). Gotta see who's got the stainless steel brake lines.. Any suggestions where i can get them from???
Re: Big brake kit
https://honda-tech.com/forums/showth...643&highlight=
Unless you are turning your civic into a full blown race car, you don't need a big brake kit or slotted rotors. The big brake kit is major overkill and therefore a waste of money. The slotted rotors will only cause you to burn through brake pads much faster.
If you want to upgrade your brakes, all you need to do is switch out the pads and the brake fluid. For the pads, your best bet would be Hawk HPS pads. Or, if you plan on tracking your car any, you could use the Hawk HP+ pads. I wouldn't recommend the HP+ pads for regular driving though since they are louder and produce a good bit more dust when braking. I use the Hawk HPS pads on my Si and they work great on track and driving around town. For fluid, any high temperature brake fluid will work.
Re: Big brake kit
here's an idea:
unless you are turning your civic into a full blown race car, you don't need a big brake kit or slotted rotors. The big brake kit is major overkill and therefore a waste of money. The slotted rotors will only cause you to burn through brake pads much faster.
If you want to upgrade your brakes, all you need to do is switch out the pads and the brake fluid. For the pads, your best bet would be hawk hps pads. Or, if you plan on tracking your car any, you could use the hawk hp+ pads. I wouldn't recommend the hp+ pads for regular driving though since they are louder and produce a good bit more dust when braking. I use the hawk hps pads on my si and they work great on track and driving around town. For fluid, any high temperature brake fluid will work.
Re: Big brake kit
Agreed with most of the comments where unless it's going to be a racecar you dont really need a BBK.. IF you still decide to find one that's cost effective.. look for used DC5Rs Brembos... they usually go for $700~ $800 for all 4.. and the rear will bolt right on but you'd need to use S2000 front rotors to bold-on the front caliper... I'm using this set-up on my FG racecar.. however, u'd need at least 17X8 +38 wheels to clear the front..
Re: Big brake kit
agreed with most of the comments where unless it's going to be a racecar you dont really need a bbk.. If you still decide to find one that's cost effective.. Look for used dc5rs brembos... They usually go for $700~ $800 for all 4.. And the rear will bolt right on but you'd need to use s2000 front rotors to bold-on the front caliper... I'm using this set-up on my fg racecar.. However, u'd need at least 17x8 +38 wheels to clear the front..
Re: Big brake kit
for those tractor wheels you MUST.....I SAY MUST.....upgrade to the BIG brake kits.........imagine the torque and the RPM generated from those "Humongous " wheels.........LOL.....LOL....LOL.......LOL
Re: Big brake kit
Yes, kit comes with Stainless Steel Lines, special fluid, Calipers, rotors (slotted or drilled) and high performance pads (which dust like crazy). HUGE difference in braking power, but as someone else mentioned, not really needed unless you do autocross races.
Re: Big brake kit
http://fastbrakes.com/shop/index.php
Check these brakes out. I disagree with people saying you don't need rotors. Take your car out for a 5 minute hard session on a back twisty road and you can beat up the stock rotors. They are not made or have a design with cooling ducts for repetative hard stops and big wheels and tires are much more stressful on stock brakes. It's not the size of the wheels that make the brakes work harder, but the weight. Each pound you add to the spinning components of the wheels and tires make your brakes work much harder.
Re: Big brake kit
Re: Big brake kit
check these brakes out. I disagree with people saying you don't need rotors. Take your car out for a 5 minute hard session on a back twisty road and you can beat up the stock rotors. They are not made or have a design with cooling ducts for repetative hard stops and big wheels and tires are much more stressful on stock brakes. It's not the size of the wheels that make the brakes work harder, but the weight. Each pound you add to the spinning components of the wheels and tires make your brakes work much harder.
Re: Big brake kit
oh so you are going for the bling factor since you have a set of 20s... well FYI it's not the size of the wheels, it's the offset of the wheels that determines if a set of BBK would clear.. just curious what type of wheels u have?
Brand New
Re: Big brake kit
http://www.motortrend.com/features/1...els/index.html
Originally Posted by COCA GROUND ASSAULT NY
Hawk hp pads??? Are they better than the ebc green stuff???
