body bars for added strength on coupe
like the tittle says im lookin for ideas on were to put some bars for body flex, i have a coupe but i was thinkin about building a pilar type bar like they have for the hb, any ideas let me here em.
Re: body bars for added strength on coupe (keenspeed94)
The Civic coupe has a tray that runs across the rear, behind the top of the rear seats, that provides rigidity. A seperate bar wouldn't make a noticeable difference. What suspension mods have you made so far?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keenspeed94 »</TD></TR><TR><TD CLASS="quote">omni coil over and type r sway bars</TD></TR></TABLE>
If you don't plan to add a roll bar, but want a little more rigidity, you might look into the typical front and rear upper and lower shock tower bars. Of course there's hundreds of different brands and styles.
If your car is a 92-95 coupe, the front lower control bar from a 94up Integra will bolt in nicely, and should be really cheap from a junkyard.
Re: body bars for added strength on coupe (rodrez.)
how about traction bars... what are you trying to achieve more rigidity for (drag, autox, etc...)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keenspeed94 »</TD></TR><TR><TD CLASS="quote">going for autox</TD></TR></TABLE>
If you're willing, a bolt in roll bar would be a great next step, and it's not very expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. »</TD></TR><TR><TD CLASS="quote">The Civic coupe has a tray that runs across the rear, behind the top of the rear seats, that provides rigidity.</TD></TR></TABLE>
thats only on the 96 and up. Ej's dnt have this.
You can also do a B pillar, c Pillar, harness bar. Also you can make some type of set up in the truck useing bars that connect the two sides of the trunk.
Blue-Civic-Hybrid
06-19-2001 08:13 PM
