Front sway bar for Civic Coupe
I just want to know if anyone has tried and suceeded with what i am about to ask... my EG(95) Civic coupe originally didn't come with sway bars and i want to put some on. The rear sway bar is no problem, it's the front one i have questions about.. I want to know if it is possible to put a GSR Front sway bar( 24mm i think) on my coupe, i looked under my friends GSR and it looks like it make bolt directly onto my chassis, but i will need GSR lower control arms from a 94-95 Integra. has anyone does this? any inputs would be nice thanks..
Re: Front sway bar for Civic Coupe (Blue-Civic-Hybrid)
A bigger than stock front swaybar will give u more understeering which you dont want. Many people disconnect their front bar or just add bigger rear bar for better rotation while cornering. It also help the front tires more planted to the ground. Good luck.
Re: Front sway bar for Civic Coupe (b18cturbo)
but that still doesn't answer my question, i will be using a stock Integra GSR sway bar, and my question is will this fit on my EG series coupe. I know about understeer, i already have it, that's why i want to put Integra sway bars front and rear on my civic to help counter it
Yes, you'll need the Teg front LCA's. I just installed mine last week (Type R front and ST rear = great handling)
Re: Front sway bar for Civic Coupe (CivicNewbie)
You could get 92-95 Civic Si front LCAs and the swaybar...I know that will fit for sure. I think the front on the Si is 22mm. If you want a larger bar you could try the 99-00 Si LCAs and the swaybar which is 26mm. I doubt the GSR sway will fit since it's probably shaped differently.
dj theoretic
10-30-2008 08:29 AM
agent marlon
10-13-2002 05:07 PM
