Best source for a chipped ecu and engine harness?
I am doing a H22 swap for a customers car of mine, and his civic did not have VTEC or a knock sensor or butterflies or EGR. To make everything cleaner I figure we should ditch the P13 ECU so we dont have to worry about the EGR and can put on a block off plate. Also for cleaner wiring I figure a more suited engine harness is due. Its a 99 Civic HX I think, I dont know there are no badges on it and its got the throttle body that faces up with a D15Y7.
The last civic I did this swap in was a 97 EX and I used a chipped ECU and OBDI adapter so I thought the wiring was very simple. However I would have to assume that a OBD II GSR harness would probably be the best if we could pick any one we wanted, cause that would even have the butterfly wiring and of course the VTEC.
Where is my best source for a used engine harness?
Where is my best source for a chipped ECU to run a OBD I H22.
-Thanks
Charles
-Thanks
Charles
Re: Best source for a chipped ecu and engine harness? (mister2racer)
i have an obd1 complee b16 wiring harness in my garage if that is anything to you let me know and we can work something out..
as for the ecu talk to Kenji
Financial Guy
09-10-2001 10:49 AM
