97 JDM ITR into 93 VX... wiring problems? HELP
Old Sep 3, 2001 | 08:07 PM
Financial Guy's Avatar
New User
Default 97 JDM ITR into 93 VX... wiring problems? HELP
Awwww junk.... I hate this wiring crap.
What is the best way to do this swap? I have the complete swap with the ECU and Distrubutor. Do I change the thing to OBDII wiring or do I go to OBDI wiring?
Please advise, need to get this thing running ASAP!
Thanks in advance!
John
John
Old Sep 4, 2001 | 06:30 AM
cjb92's Avatar
Default Re: 97 JDM ITR into 93 VX... wiring problems? HELP (Financial Guy)
If you could get a complete engine wiring harness from a vtec 96-98 civic or obdII gsr you could use that to plug into the stockobdI underdash harness and use an ecu jumper from kenji for your itr ecu and call it a day. Other wise you could get an ecu jumber and convert the obdII ecu to obdI plugins and add only 1-2 wires on the stock civic harness and also call it a day.
Old Sep 4, 2001 | 11:18 AM
paulzy's Avatar
Default Re: 97 JDM ITR into 93 VX... wiring problems? HELP (superflea)
obd1 gsr main engine harness and a jumper from kenji to run the obd2 ITR ECU. Then wire in the knock
Old Sep 4, 2001 | 02:05 PM
Katman's Avatar
Default stick with OBD1...
its your best bet.
I believe you can reuse your VX engine harness, since you have VTEC already. Or get a hold of an Si/EX engine harness.
Try and sell the ITR distributor or trade it for a B-series OBD1 distributor - do the same with the ECU also. If you can, go with a 92-95 Si/EX ECU aka P28 and have it reprogrammed - it will run better than a ITR ECU, even better once it's tuned.
This will make everything plug n' play.....then you won't have to deal with wasting your $$ on an ECU jumper which will only allow you to run the unchippable ITR ECU. (well it is chippable..but mucho deniro!)
good luck...
Old Sep 5, 2001 | 11:18 AM
bojangs's Avatar
New User
Default Re: stick with OBD1... (Katman)
what about the injectors? repin the obd2 plugs on the obd1 harness or run the obd1 injectors? i thought the alternator plug was different as well between obd1 & 2.. that tru?
Old Sep 5, 2001 | 06:31 PM
Katman's Avatar
Default oh yah..woops!
ha..forgot about them injectors...He'll have to get some OBD1 B-series injectors also....he shouldnt have a problem trading/selling his ITR inj.
Yes..the alternator plug is square rather than round on the obd2 alt. plug, he'll have to cut n' splice or trade/sell for an OBD1 alt.,
Old Sep 10, 2001 | 07:51 AM
New User
Default Re: oh yah..woops! (Katman)
Hey, here is what I have done. Got a 96 GSR harness and plugged it in to the stock under dash harness. Now, do I run a chipped P28 or buy a jumper and run the ITR computer? Help oh wise Katman!
Thanks,
John
Old Sep 10, 2001 | 08:29 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: oh yah..woops! (Financial Guy)
I'd go chipped P28.
Old Sep 10, 2001 | 10:49 AM
GZR4DR's Avatar
Default Re: oh yah..woops! (B18C-EJ1)
The absolute easiest way is to get a 96-01 integra GSR engine harness. It will plug right up. No wiring necessary. You might have to extend a couple wires, but nothing big. To use the ecu, you will need to get a harness converter. Or do like Katman said and get a mugen chipped p-28. That latter will run better anyways. His way of installing the engine with the old harness will work, but i think it will be easier to just find a 96+ GSR engine harness. Or even a 96+ integra LS harness and just wire the knock and vtec wires directly if you cant find a GSR harness.
Unphzd
18
Aug 24, 2010 07:25 PM
prime-R
Mar 1, 2009 12:17 PM
ITR_EGG
Jan 3, 2006 09:43 PM
h45454
Jan 8, 2003 06:02 PM
