Behind Fhywheel??
Old 02-13-2005, 09:11 AM
XzzYzzX's Avatar
Default Behind Fhywheel??
Just took my stock flywheel off my b16, replacing with lightened unit. Now what is the pump looking thing behind the flywheel? Do I need to replace that? Should I?
Old 02-13-2005, 09:26 AM
92civicb18b1's Avatar
Default Re: Behind Fhywheel?? (XzzYzzX)
pump behind the flywheel...am i missing something. I don't remember anything like that. You sure your talking about the flywheel and not the crank pulley?
Old 02-13-2005, 09:36 AM
mrchaos's Avatar
Default Re: Behind Fhywheel?? (92civicb18b1)
yeah behind the flywheel is the main oil seal....behind crank sproket is the oil pump.
Old 02-13-2005, 09:42 AM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Behind Fhywheel?? (mrchaos)
He may just be refering to the plate the flywheel bolts up to. Who knows, never seen any pump there.
Old 02-13-2005, 09:43 AM
XzzYzzX's Avatar
Should that be replace, I just bought the motor from Hmotors...Yea it like the plate that bolt to the flywheel.....
Old 02-13-2005, 10:04 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XzzYzzX &raquo;</TD></TR><TR><TD CLASS="quote">Should that be replace, I just bought the motor from Hmotors...Yea it like the plate that bolt to the flywheel.....</TD></TR></TABLE>
no just bolt your new flywheel on and enjoy the quicker revs
unless of course its leaking oil like a civ, replace the seal in that case
Old 02-13-2005, 10:54 AM
Do_Ster's Avatar
replace the seal. it's preventive maintenance. it's not that expensive.
Old 02-13-2005, 11:46 AM
Default Re: (Mr.LadyBug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.LadyBug &raquo;</TD></TR><TR><TD CLASS="quote">replace the seal. it's preventive maintenance. it's not that expensive.</TD></TR></TABLE> I agree, how much fun is it to drop the trans, pull the clutch and flywheel JUST to replace a little rubber seal that costs (most likely less) $12? I don't like chinsing when it comes to my car. Her name is Desiree BTW...
Old 02-13-2005, 12:04 PM
mrchaos's Avatar
Default Re: (HondaFanatic708)
plate the flywheel bolts to? thats the crank....is the engine from an automatic?
Old 02-13-2005, 12:25 PM
Default Re: (mrchaos)
he means the mounting plate for the flywheel.
I've never done it or even looked into or know anything about it. But what about the pilot bearing, i think he should replace that....but I don't know I may be stupid and it comes on the flywheel or something.
But yea, you might as well replace that seal wile your in there. I think I might cause I need a new trans even though I have no leaks whatsoever.
Old 02-13-2005, 02:59 PM
Default Re: (92civicb18b1)
Usually that little baring comes with a clutch kit (I know CM gives you one) and yes you should replace that as well as the rear main seal.
Old 02-13-2005, 03:12 PM
SOHCD16y8's Avatar
throwout bearing almost always comes, and always do the main seal, cheap preventive maintenance
Old 02-13-2005, 05:47 PM
XzzYzzX's Avatar
Default Re: (SOHCD16y8)
Yes my exedy clutch kit came wit the pliot bearing which was replaced on the lightened unit already, no the plate is not leaking, it looks fine to me, Thanks for all the replies
Old 02-13-2005, 06:00 PM
Risky Business
BauleyCivic's Avatar
Default Re: (XzzYzzX)
Definitely replace the rear main seal...
Don't want this to happen to you:
Old 02-13-2005, 10:52 PM
Do_Ster's Avatar
also make sure to get a helms when replacing the rear main seal. i believe it's has to be within a certain spec so your flywheel doesn't contact and **** it up
Old 02-14-2005, 02:51 AM
XzzYzzX's Avatar
Default Re: (_OEM_)
Ok, got that on order, Thanks guys for all the replies....
Old 02-14-2005, 04:15 AM
yea, i never even attempted to put the pilot bearing in, although every kit I got came with one. I never even bothered taking off the flywheel this time.
xduB95preludeSi
09-09-2016 06:37 AM
92 gs INTEG
01-31-2007 09:42 PM
.Thomas
01-16-2007 10:45 PM
ITR-2001
08-16-2006 02:02 PM
Quick Reply: Behind Fhywheel??
