Behind Fhywheel??
Behind Fhywheel??
Just took my stock flywheel off my b16, replacing with lightened unit. Now what is the pump looking thing behind the flywheel? Do I need to replace that? Should I?
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: Behind Fhywheel?? (mrchaos)
He may just be refering to the plate the flywheel bolts up to. Who knows, never seen any pump there.
Should that be replace, I just bought the motor from Hmotors...Yea it like the plate that bolt to the flywheel.....
Re: Behind Fhywheel?? (XzzYzzX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XzzYzzX »</TD></TR><TR><TD CLASS="quote">Should that be replace, I just bought the motor from Hmotors...Yea it like the plate that bolt to the flywheel.....</TD></TR></TABLE>
no just bolt your new flywheel on and enjoy the quicker revs
unless of course its leaking oil like a civ, replace the seal in that case
Re: (Mr.LadyBug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.LadyBug »</TD></TR><TR><TD CLASS="quote">replace the seal. it's preventive maintenance. it's not that expensive.</TD></TR></TABLE> I agree, how much fun is it to drop the trans, pull the clutch and flywheel JUST to replace a little rubber seal that costs (most likely less) $12? I don't like chinsing when it comes to my car. Her name is Desiree BTW...
Re: (mrchaos)
he means the mounting plate for the flywheel.
I've never done it or even looked into or know anything about it. But what about the pilot bearing, i think he should replace that....but I don't know I may be stupid and it comes on the flywheel or something.
But yea, you might as well replace that seal wile your in there. I think I might cause I need a new trans even though I have no leaks whatsoever.
Re: (92civicb18b1)
Usually that little baring comes with a clutch kit (I know CM gives you one) and yes you should replace that as well as the rear main seal.
Re: (SOHCD16y8)
Yes my exedy clutch kit came wit the pliot bearing which was replaced on the lightened unit already, no the plate is not leaking, it looks fine to me, Thanks for all the replies
pentaq
04-29-2003 04:36 AM
