Removing Flywheel ... How to stop it spinning?
Hi, i am putting in a new flywheel and clutch. and when i remove the old one it spins, any way to stop this or deal with it?
thanks
thanks
Re: Removing Flywheel ... How to stop it spinning? (TanCar)
have sumone hold it with a 19 mm wrench/socket on the other end...or if its on the ground...put the wrench on there and it will jamm itself on the floor...
Re: Removing Flywheel ... How to stop it spinning? (iBrandon)
sorry, I had an impact for zzipping those off but yeah - similar technique as mentioned by iB works well when I was putting the flywheel back on, I had the motor on the ground - had my 1/2" breaker bar on the crank pulley bolt and wedged that to the ground so I could torque down the flywheel bolts - worked great!
the flywheel is drilled all the way through.... its simple. just put a screw driver through one of those holes under the engine so when you turn the screw driver hits the engine and stops the flywheel the bolt will come loose
pantherninja
12-11-2011 06:14 PM
JDMInspired
Honda Civic (2001 - 2005)
03-17-2008 08:57 AM
