B18A vs. SOHC Turbo..yes again...
So i found a B18A engine full swap for $899. Or should I just stick with my original plans of the Turbo. This is a daily grind so what is the upkeep on each of these engines. Very minimal labor on the swap, heavy discount labor on the turbo and the price of the turbo barely above cost. Please give me some stuff that I can work with here and not the usual banter of which is prefered. I would like to hear the pros and cons from those of you who have them. The next up is the B18C and that jumps into the $2000 range for the front clip. That do you all think?
Re: B18A vs. SOHC Turbo..yes again... (uncivilCivicinprogress)
I beat b18c hatchs w/ my sohc turbo. plus it makes a cool "psst" sound when i shift...
Re: B18A vs. SOHC Turbo..yes again... (BlackNoise)
for a b18a that is expensive as hell. I was gonna pick up a b18a block the other day for 50 bucks but opted not too. I wish i did though. I've seen a few blocks here in houston go for 1000 for a b18b swap.
Re: B18A vs. SOHC Turbo..yes again... (SilverCivic2k)
You know I spoke to my buddy today, he said that it is not a B16A1, but a B18B. I was alos thinking, how compatable is the Turbo set up on a D16Y7 with a B18B if I were to change the engine later, would I be able to swap the turbo over without too much hastle?
Re: B18A vs. SOHC Turbo..yes again... (piscorpio)
you'll need a new manifold, and im not sure of all the other parts you'll need, but the turbo will spool up a lot quicker because it's a smaller turbo meant for the sohc motor. what turbo kit is it ? is it Greddy, Rev Hard ?
Re: B18A vs. SOHC Turbo..yes again... (IhateMy93BlackHatch)
The Greddy. I think that is what I am planning to do...and get a B18C5, I got a guy whose gonna give me a front clip for $2500, under 50k guaranteed, but I can't get that cash yet.
Re: B18A vs. SOHC Turbo..yes again... (RiceD16)
So now your going to get a b18c5 front clip for 2500? And put a greddy turbo kit on it? That would be a good waste of a motor if you did that......Unless you plan on spending some cash to get it "Properly"set up. Just me $.2
yea so like the B18a is what like 140 off the flywheel???? Unless you do a conversion screw it. Besides its an older engine right? so how would you be more relyable?? it would have high mileage right?
Besides the sway compared to a turbo install is totally different, swaps are a pain in teh *** where a turbo can be setup in a matter of hours.
go turbo with some minor internal work, cams and stuff...
Re: B18A vs. SOHC Turbo..yes again... (PostWhore)
Why would that be a waste of a motor?
the greddy
the greddy
the short gearing of the tranny.
not optimized for a turbo, optimized for an all motor set up.
why not just boost the ls? ls is a dime a dozen for the engine if he blows it unlike an r, and the compression is more boost friendly, as is the trannies longer gearing.
ANd the fact that you could get a better kit pieced together for about the same as price the greddy would run.
Re: B18A vs. SOHC Turbo..yes again... (greebler)
