b16 wire harness or y8?? HELP!!
ok so here is my problem.. i have a 2000 hatchback.. and im doing a b16a swap into it. i dont have any wire harness at all because i sold it with the last motor that was in there.. and the wire harness i got with the motor was for eg obd1. so do i need the obd2 harness?? for b16? or i heard somehting bout using a y8 harness will work??
any help would be aprecieated.. thanks
I'm not Rick!
Re: b16 wire harness or y8?? HELP!!
sum guy on here knew how to use the other harness with another obd2 setup.
what obd and year is that motor?
if the b16 is obd2 you can use your y8 harness. if not you got do some work
To answer your question though a Y8 harness will work fine
wat will i have to do to the y8 if i got it to make it fit with the b16? i heard the distributor plug is different.. is that true? cause i found a y8 but im not sure of buying it..
i know.. my car is obd2 and the b16 is obd2... but if i buy the y8 obd2 harness will it fit perfectly or do i have to play with some wires?? and if so which wires?
you will have to fiddle with the dizzy plugs and some other wire im not sure. but yeah it will work just a couple wires u will have to fiddle with
I'm not Rick!
www.rywire.com ....he has tech answers that answer specifacly what your asking
mario_pic
11-15-2007 10:57 PM
tallblondkid
11-20-2004 02:45 PM
