quick question on wire harness???
Old Nov 18, 2006 | 02:14 AM
gsrious's Avatar
Default quick question on wire harness???
the car(92-95 civic cx) comes equiped with obd1.
the ordeal is that we are swaping out the motor for a 2000 gsr motor. the motor comes with the obd2 engine harness intact.
? is can we just plug the obd2 engine harness right into the harness of the car(obd1) going in to the ecu and be working perfectly fine?
^^trying to get the motor barred, but for obd1, NOT obd2.
Old Nov 18, 2006 | 05:13 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: quick question on wire harness??? (gsrious)
yes, I think there may be some extra plugs on the shock tower harness but it'll work
http://www.ff-squad.com/techne...2.htm
Old Nov 18, 2006 | 04:20 PM
0554's Avatar
yes it will work .
0554's Avatar
but you are still going to have to wire for vtec
Old Nov 19, 2006 | 10:24 AM
gsrious's Avatar
we are going to pin a wire from the ecu to the shock tower,then just pluging in the obd2 harness to it.
^^that should work right? i think so...
if im not mistaken... " This is a key ingredient in getting an OBD2 engine to work in an OBD1 vehicle. The Honda geniuses were cool enough to make the US OBD2 integra engine wire harness backwards-compatible with OBD1 vehicles. "
^^that is my answer
Old Nov 19, 2006 | 10:31 AM
gsrious's Avatar
btw, thatnks guy for your inputs.
Austin Gossling
Apr 12, 2017 03:32 PM
chikichimo
Oct 28, 2011 04:16 PM
all-mtr-teg
Oct 19, 2009 12:16 PM
B18CUL8R
Dec 23, 2008 09:58 AM
3k9civic
Feb 1, 2005 09:02 PM
