Which Harness?
Re: Which Harness? (B18C_DC2)
use the stock harness, modify necessary plugs (dizzy, injectors, altenator, etc) to plug into obd2 motor. or u can just use ur stock harness and swap the obd2 parts on the motor with obd1 parts. the obd2 harness wont plug into you car w/o lots of mods
Re: Which Harness? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">just keep your stock harness, and buy an obd2 - obd1 conversion harness to make things easy.</TD></TR></TABLE>
WTF???? He has a 94 obd1 hatch. He is putting in an odb2 motor. Where exactly does this harness adaptor go??? OBD2 civic harness is one complete harness to the ecu. OBD1 civic has the shock tower plugs.
Reuse old distributor, injectors, and harness. Add VTEC wires if needed. Let here rip.
What exact model is your hatch? Is the new motor going in from a auto or 5speed? Let me know I will will try to point you in the right direction. Its not going to be hard at all. That swap is pretty straight forward.
HAnda-Tech Member
Re: Which Harness? (b18cx)
i have a 94 civic DX hatchback 5 speed (d15b7, not like you need to know)
puttin in a 2000 civic ex d16y8 5 speed with a P28 (obd1 ecu)
and Skunk2 sells odb2 engine to odb1 ecu harnesses for $283.00
http://www.lightningmotorsport...c.htm
TSPeed Factory
ohhh whoops. i read that wrong then. yeah, ignore what i said. hope you're familiar with wire cutters and crimps cuz you're going to be doing a lot of that.
honda_hackett
11-25-2008 01:17 PM
tallblondkid
11-20-2004 02:45 PM
