B-16 swap into EG ( question on cable and hydro clutch cables?????
I have a 93 civic Hatchback, it's automatic and I'm swaping In a b16 from a 91 CrX Si, I heard that the 92-95 have hydro clutch and under that year is cable?? I was also told that when put in the clutch pedal it won't line up either due to the fact? So is there a way to convert it and make it work? And can I use the clutch pedals and lines front the CRX on my EG??
The Grumpiest
Re: B-16 swap into EG ( question on cable and hydro clutch cables?????
I don't think the CRX came with a B16 in the US ever? In any case, cable to hydro conversion kit.
But, I'm no expert in ancient swaps.
Seagull Management
Unless you're getting this swap for nothing or next to nothing get an OBD1 engine and hydro trans. If you insist on using this engine at least get a hydro trans and pedals (you'll want all 3) from any '92 - '95 Civic or '94 - '01 Integra 5 speed) You'll also need the shift linkage, rear engine bracket and lower torque mount brackets from a '94 - '01 Integra. You'll need an OBD1 B-series vtec distributor, OBD1 injectors, and an OBD1 B16A ECU.
streetsold6teeny8
05-13-2010 04:17 PM
PINKS
04-17-2007 06:43 PM
