help!!!! transmittion
I have a 91 crx with a jdm b16 that i am loking to sawp into my eg hatch. but i noticed the g has a hydrolic clutch and the crx has a cable clutch, is there ne way i can still swap them with what i have as is?
Ek Forever y0!
Re: (deadline)
Yep, you'll need a hydro b16 tranny for your hydro eg.
If you want to put the motor you have in you eg into your rex you'll need a cable tranny or switch it do hydro via a conversion kit. Which tend to get expensive.
Ek Forever y0!
Re: (livebytheboard)
A cable transmission shifts via cables from your shifter to your tranny essentially.
A hydrolic transmission uses a shift linkage and shifts via a slave cylinder which pressurizes fluid through the lines to engage the clutch/shift assembly.
yeah but i was thinking of removing the master cylinder, since the slave comes off w/ the transmittion, then one i have the master removed i can run the cable on the other trans thru my firewall and attatch it to my clutch pedal. would that work?
Ek Forever y0!
Uhhhh... Not really. I don't think your following.
it won't be compatible unless you buy a special conversion kit that has special mounts and brackets.
Bottom line, just save yourself the headache and get a hydro tranny.
DACteg
02-08-2008 08:15 PM
lilo_goki
13
05-09-2007 10:34 AM
xlusiveracer
02-28-2005 02:32 AM
