anyone tips on putting a/c tensioner on?
Re: anyone tips on putting a/c tensioner on? (jdm_nothing)
hope you have small hands
If you want
put a jack under the oil pan (make sure there is a piece of wood between the jack and the oil pan)
Take the timing belt motor mount off and jack the motor up for more clearance on the top side of the engine and low it for more clearance on the bottom side
it helps if you move the power steering pump out of the way
If you want
Re: anyone tips on putting a/c tensioner on? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">hope you have small hands
Ill second that one. Its a real sob to put on. The power steering belt has to be removed if its still on because the ac goes behind it. I know on the 92-95 chassis you have to remove one of the motor mounts too.
turbotime
05-27-2006 04:54 PM
