Anyone know if JDM b16a AC bracket will work?
Will a jdm b16a AC bracket work in a EG with a USDM 99 b16a2? I'll be using the stock 92-95 USDM compressor.
Re: Anyone know if JDM b16a AC bracket will work? (Apex i ITR)
It will work but if your using your d series compresser you will only be able to put 2 of the bolts in it as the other 2 dont line up.
Re: Anyone know if JDM b16a AC bracket will work? (zigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zigs »</TD></TR><TR><TD CLASS="quote">It will work but if your using your d series compresser you will only be able to put 2 of the bolts in it as the other 2 dont line up.</TD></TR></TABLE>
this is correct. Only the two upper and lower holes on the right side of the bracket will line up!
Yup.....if u r using the SOHC Compressor, the comp. will only be held on by 2 screws. I just got a CRV bracket and the SOHC compressor worked with all 4.
Lok1
07-26-2018 09:01 AM
EJ8 GSR-T
46
09-17-2009 06:47 AM
crazyguy
08-06-2007 08:22 PM
vtecdc2
20
10-03-2003 09:41 PM
