Need ac bracket for b series motor..with d series compressor
I need a bracket that will bolt up for my ac compressor to a gsr motor, but the compressor is off of my d16y8...someone said that a CRV bracket will work, is there any truth to this?
what will work?
what will work?
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">what year car are you using?
92-95 civic= Del Sol vtec Bracket or CRV bracket
96-00 civic= Si Bracket
Re: (EJ8 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">Its a 98 coupe....but will the si bracket work with the d series ac compressor? </TD></TR></TABLE>
I believe honda has kept the same AC compressor design so in theory it should work.
Re: Need ac bracket for b series motor..with d series compressor (EJ8 GSR-T)
If you need a bracket such as del sol or integra A/C brackets. Give jdmland a call. They can help you out.
Re: (EJ8 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">badass can anyone confirm this?</TD></TR></TABLE>
Re: (EJ8 GSR-T)
yes i believe the 94-97 (i think those years?) crv bracket will work. but there was something about what block you were using. if it was a b16 you couldn't have powersteering or was it b18? i dunno. something about the deck height and with one of them you can't have powersteering.... i know for a fact that the crv bracket will work tho. lol.
Re: (JDMlyfestyle)
bracket off B16's
+ tha B-series off tha CRV
_taF
bracket off B16's
_taF
Re: (tallazzFilipino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallazzFilipino »</TD></TR><TR><TD CLASS="quote">
bracket off B16's
_taF</TD></TR></TABLE>
what?
bracket off B16's
what?
You are looking for a P7J bracket from a CR-V or the P54 bracket from a del Sol. The P7J is cheaper from Honda and will run you around $70.00 if I recall correctly. I purchased one a few years back for a B18 swap with a D-series compressor.
Re: (EJ8 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">come on guys i need a straight answer</TD></TR></TABLE>
the bracket you will need are/or :
part# 38930-P54-000 b16 del sol
part # 38930-P7J-000 crv
the 99-00 civic si uses the 38930-P30-000 bracket as well as 96-97 delsol's (w/b16). these models use the same compressors as the integras and are not compatible with the a/c lines from the d-series setup.
Re: (EJ8 GSR-T)
i just used a p72 bracket. 2 bolts on the a/c compressor will work. that's all that's needed to hold it. i dunno, i'm ghettoooo. been runnin like that for a while with still ice cold R12 (92 hatch[b18c1])
Re: (inline4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">part # 38930-P7J-000 crv
honda wants 1-- ******* dollars....can i get some assurance this will work?</TD></TR></TABLE>
yeah i know my dealer is asking for the same. it will work!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4 »</TD></TR><TR><TD CLASS="quote">i just used a p72 bracket. 2 bolts on the a/c compressor will work. that's all that's needed to hold it. i dunno, i'm ghettoooo. been runnin like that for a while with still ice cold R12 (92 hatch[b18c1])</TD></TR></TABLE>
yeah the P72 and P30 use the same compressor. eventually, while using 2 bolts your compressor is going to rip out. i've heard and seen it too many times.
Re: (EJ8 GSR-T)
i was sayin' you can use tha bracket off any of tha B16's and tha bracket off tha B-series CRV.
i have a 94 JDM B16A. i used to have a 99 B16A2 bracket on there, but accidentally left it in my first hatch when i sold it. i still have tha engine and am now usin' a 95 B16A3 bracket. i got both of them from tha junkyard, $10 all day. am usin' tha AC compressor off tha D16Z6. each time i had this setup, it was in an EH3 (92-95 Si hatch).
_taF
_taF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallazzFilipino »</TD></TR><TR><TD CLASS="quote">i was sayin' you can use tha bracket off any of tha B16's and tha bracket off tha B-series CRV.
good lord, here we go again. no you can't use any b16 bracket, the only b16 bracket that can be used is the P54 bracket. any other b16 uses the P30 (even the jdm b16, 99-00 si b16, and the 96-97 del sol b16). the brackets you used must of been the P54 and you didn't realize it. the P30 brackets take the same size compressors the integras do, the civics have smaller compressors. and the 2 bolt thing is not going to work, they have the tendency to loosen and fall off.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
any other b16 uses the P30 (even the jdm b16, 99-00 si b16, and the 96-97 del sol b16).</TD></TR></TABLE>
so, you're sayin' tha JDM B16 uses just tha P30 bracket?
and the 2 bolt thing is not going to work, they have the tendency to loosen and fall off.</TD></TR></TABLE>
tha 2 bolts will loosen up anyway? so, they had to have been able to go in first, before bein' able to loosen up?
_taF
_taF
yes they use the P30, i have one in my garage from my jdm b16a (92-95 sir2). so does the 96-97 del sol b16 and the 99-00 em1 b16.
and yes you can mount the compressor with 2 bolts onto the P30 but it's not reliable. when you get on it after a while the bolts either snap or come loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T »</TD></TR><TR><TD CLASS="quote">I need a bracket that will bolt up for my ac compressor to a gsr motor, but the compressor is off of my d16y8...someone said that a CRV bracket will work, is there any truth to this?
what will work?</TD></TR></TABLE>
It is the truth.
I am using the CRV bracket in my car. I have '00 SI b16a2, and the A/C compressor from my '00 DX d167y and the CRV brackets connects the two perfectly.
You can also use a bracket from the Del Sol, but they are more expensive.
Mr. Indecisive
Re: (JDMlyfestyle)
not to be a dick but let me fix this
92-00= Del Sol vtec Bracket p54 or the CRV, those are the only ones that will work. I Had the same problem. SI brackets are the same as gsr ones, and ur d series compressor wont bold up.
