anybody tried 32 offset before?
i'm looking at these very nice 15" wheels but the offset is 32. do you guys it's gonna rub on an EK with ~1.8 drop?
thnaks in advance. Modified by atermizi at 11:30 PM 7/25/2004 |
Re: anybody tired 32 offset before? (atermizi)
i have a +32 on 16x7.5 It rubs because my car is dumped.
Re: anybody tired 32 offset before? (integlspwr2k)
how much drop ?
It was pretty much slammed to the earth..
http://subaseproject.com/mycarslammed.jpg Can you can see the rear kinda sticks out a little then the front. |
search for the thread asking about +42mm offset wheels i run a 15x6.5 +32 wheel with 195-55-15 tires and only minimal rubing
Re: anybody tired 32 offset before? (slammed_93_hatch)
Re: anybody tried 32 offset before? (atermizi)
It all depends on the width of the wheel. You could run a 0 offset if wheel was narrow enough. Also, the size(width and profile) of the tire will make a difference. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: anybody tried 32 offset before? (jg)
how about 15x7 with 32 offset?
Stupid question: positive offset would only give you the issue of rubbing the outside of the fender/quarter panel, and not the inner portion, right? Or am I way off?
the smaller the offset, the farther out it's going to sit. If you have a larger number, you're more likely to rub the inside fenderwell.
Re: (JRl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRl »</TD></TR><TR><TD CLASS="quote">If you have a larger number, you're more likely to rub the inside fenderwell. </TD></TR></TABLE>
Or you could rub the inside of the rim on the knuckle. |
Re: (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">Or you could rub the inside of the rim on the knuckle.</TD></TR></TABLE>
yep so its better to get a higher offset its easier to roll you fenders then it is to shave down your knuckle etc.. |
Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
yep so its better to get a higher offset its easier to roll you fenders then it is to shave down your knuckle etc..</TD></TR></TABLE> Gotcha, thanks https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (integlspwr2k)
yep so its better to get a higher offset its easier to roll you fenders then it is to shave down your knuckle etc..</TD></TR></TABLE> you mean lower offset right? lower (positive) offset: wheels stick out more |
Re: (dantastic)
to make things clear, the closer a POSITIVE NUMBER get to ZERO the futher out the wheel is pushed. most stock wheels are around +45 to 47.
