no cel at all help
no cel at all help
Ok I just recently finished my new all auto meter dash gauges looks great BUT everything works execpt the cel tryed hooking factory gauges back up doesnt work there either now not sure what it is
It is not a bulb tryed that could it be something fryed in the ecu or a blown fuse
Any help would be great thanks
Dustin
Dustin
Re: (troubledsol03)
I dont get what you did that would stop the CEL from coming on. Did you put a different gauge cluster in there, did you put indiglos in, what exactly did you do? You are being very vague.
I replaced every gauge with an auto meter gauge tach speedo fuel level coolant temp and used LEDs for all the indicator lights everything is attached to a peice of carbon fiber and installed in the factory location
Re: (troubledsol03)
Did you disconnect the batt. before you started doing all this?
Check the bulb. If everything else is working then i doubt its a fuse. Do you have pics of this?
SOHC_civic_si
19
06-01-2008 10:20 AM
