99 Civic Si Car dies while driving
So I have a 1999 Honda Civic Si ( Canada so the D16Y8 SOHC Vtec ) Hoping someone can shed light on my issue
Car keeps dying while driving ( Just Engine )
I have noticed the Check Oil Light and Battery Light come on ( If that helps ) Saw something posted about those dash lights somewhere
here is what I have replaced so far
Crank Shaft Position Sensor
Alternator
Goes in next week for Timing Belt as that needs replaced
Maybe someone knows what the issue could be?
Alternator
Re: 99 Civic Si Car dies while driving
Does it restart after waiting a few minutes? If you're on the freeway, does it restart on it's own? If so, check the distributor because you're probably not getting spark 100% of the time.
Yes it will restart after I wait a few minutes, Wont Start on its own I have to turn key to off and restart it, I will definately check Distributor, Could also be Main Relay, almost didnt start for me today, Possibly Ignition Coil? if not these could I be missing something?
Can you restart immediately or is there a period where it will crank but not start?
In that latter case check for spark during the time that it will not start. The ignition module is a common cause of this, it will stop working when hot and work again after it cools.
Also check for any ECU codes.
JGraver92
05-12-2019 10:05 AM
Aurogers
06-19-2017 06:41 PM
hotdoggies
15
02-10-2011 04:37 PM
EvrClrx311
20
05-19-2004 09:04 PM
