99 Civic Si Car dies while driving
So I have a 1999 Honda Civic Si ( Canada so the D16Y8 SOHC Vtec ) Hoping someone can shed light on my issue
Car keeps dying while driving ( Just Engine ) I have noticed the Check Oil Light and Battery Light come on ( If that helps ) Saw something posted about those dash lights somewhere here is what I have replaced so far Crank Shaft Position Sensor Alternator Goes in next week for Timing Belt as that needs replaced Maybe someone knows what the issue could be? |
Re: 99 Civic Si Car dies while driving
Does it restart after waiting a few minutes? If you're on the freeway, does it restart on it's own? If so, check the distributor because you're probably not getting spark 100% of the time.
Originally Posted by Alex98
(Post 51918600)
Can you restart immediately or is there a period where it will crank but not start?
In that latter case check for spark during the time that it will not start. The ignition module is a common cause of this, it will stop working when hot and work again after it cools. Also check for any ECU codes. |
Originally Posted by mk378
(Post 51918741)
