98 Civic Si (CDN) or EX - SOHC VTEC embossed valve cover?
Hi there,
I'm looking at buying a 1998 Civic Si (I know it's an EX coupe in the US). Car is in great shape.
When I popped the hood I was expecting to see SOHC VTEC embossed valve cover, but it looked like just a regular SOHC cover. There were no VTEC markings on it whatsoever.
Where does one find the engine code markings? I'm a total Honda newb so any help is appreciated!
Wondering if this is normal or if perhaps the car has had the engine swapped.
Thanks in advance.
Thanks in advance.
Re: Question about 1998 Civic Si (CDN) or EX
Vtec solenoid is located on the upper left corner of the head. It has a cylinder, if you google it I'm sure you can find pics to help.
Also under the upper radiator hose, there's a flat section on the engine block that will have the engine code.
D16Y8 = VTEC
D16Y7 = non-VTEC
D16Y8 = VTEC
D16Y7 = non-VTEC
Re: 98 Civic Si (CDN) or EX - SOHC VTEC embossed valve cover?
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Seagull Management
'96 - '00 Civics with a D16Y8 don't say vtec on the valve cover. '97 - '00 Acura ELs do say 1.6L Vtec on the valve cover though.
If you want to get a VTEC valve cover for your D16Y8 - get a 1992-95 EX/Si D16Z6 one from a junkyard (new ones are discontinued from Honda). I did this and also painted it with VHT wrinkle red for the JDM look. I am buying the chrome oil cap from ICB motorsports for $21.97.
Petah
09-01-2002 04:20 PM
