97 civic, no power...
whats up ht, i have a 97 civic with a ls swap, car was running great up until today, go out to start the car put the key in the ignition and i have no power at all, thought it was the battery replaced it and still nothing, any ideas?
Re: 97 civic, no power...
check for any shorts in the battery wires i might suggest moving the ground wire for the battery to another location cause the same thing happened to me i moved it and the car started right up.
Check the battery ground like others have suggested, and make sure both + and - connections are solid and tightened.
Next, I would try moving the ground to a different location like Castillo847, as I've had friends do the same it work for their car.
Let us know what happens
ok i got a test for you to try put a ground wire from the negative terminal from your battery to the top bolt on your distributor it is another ground that might help
Maria V Martin
11
07-20-2018 04:02 PM
whatisbrokennow
05-03-2010 03:40 PM
ChevelleSSLS6
10-22-2009 08:32 PM
