97 Civic HX -- Fuel pump won't run
OK so I have replace fuel pump and main relay but the fuel pump still will not come one with being hooked to a switch is there anything else to check
Re: fuel pump issue
Good. That's clear.
Now also run a wire from the - battery post to the black ground wire for the fuel pump. When you flip the switch, does the fuel pump now run?
Re: fuel pump issue
Voltage test installed fuses 44 and 13.
Check whether the G101 ground on the thermostat housing is clean and tight.
When you turn the key from off to ON(II), does the CEL remain on steady?
Any CEL codes?
00trdtaco
08-20-2009 06:42 AM
94delsol6428
12-22-2006 12:51 AM
