Fuel pump kill switch....
Old Dec 19, 2006 | 01:24 PM
EJ8 GSR-T's Avatar
Default Fuel pump kill switch....
I installed a fuel pump kill switch, and it works, but i want to hook in an LED so i will know if the pumps on or not. I dont know what the best way to wire it in though, if the LED shorts or something stupid i dont want it to cut fuel pump power so how can i wire it in?
Old Dec 19, 2006 | 03:38 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">but i want to hook in an LED so i will know if the pumps on or not.</TD></TR></TABLE>
The fact that your car is running is not a good enough indicator that the pump is on???
Old Dec 19, 2006 | 03:46 PM
EJ8 GSR-T's Avatar
Default Re: (B18C_EJ8)
yeah it is, lol but i would rather have a light that i can look at, its much easier then trying to remember if i hit the kill switch or not.....probably 30 min of work for soemthing that can make everyday driving easier
Old Dec 19, 2006 | 06:44 PM
EJ8 GSR-T's Avatar
Default Re: (EJ8 GSR-T)
Old Dec 19, 2006 | 07:08 PM
fcm's Avatar
fcm
Old Fart
It's not that hard, install a 1A-2A switch on the PGM-FI Main Relays ground lead, [black], it is low current, you can add the ground of a 12V LED to the relay side of switch and connect the LEDs pos.(+) to a 12V+ ign. source, the 2nd ign. free pin on the under dash fuse box would work, a diode may also have to be installed on the line going to the PGM-FI Main Relay, to isolate the LED from the relay
If the above is done properly the LED will be on if the "kill"switch and ign. is on and off when the "kill" switch is off, and when off, fuel pump relay can not turn on, or can the injectors power relay, engine will not even fire and run for a few sec. 94
Old Dec 25, 2006 | 06:46 PM
building boost's Avatar
lol just listen for the fuel pump before u turn the car on.
SunnySideUp
Jul 1, 2011 07:47 AM
00trdtaco
Aug 20, 2009 06:42 AM
TurboEM1
Audio / Security / Video
Feb 28, 2006 12:43 PM
Swift1
Oct 26, 2005 11:20 AM
jedubz
31
May 23, 2004 06:09 PM
