96 civic ls v tek turbo
i have a 96 civic Ls v tek turbo and when i start up my car it works fine when i start steping on the gas it chokes and deaads out what dose that means?
Re: 96 civic ls v tek turbo (AzNsTyLe361)
i'm glad you didn't try to use spell checker before you posted that, because if you had chances are your computer would have committed suicide.
what ECU are you running? what fuel pump? injectors? did the car run fine beforehand and this is a new problem? things we need to know. maybe you are out of gas?
Re: 96 civic ls v tek turbo (forcefedferio)
anywayz sorry about my spelling am running 99 gsr ecu wellbrock fuel pump and stock gsr injectors and yes i have gas in my car and i thought it was the map sensor i change that too and it still do the same .
and i was boost 7 lb then it just start choking i thought it was the vac line it vac lind still suck so dont know the problems help ?
you're car is getting nowhere near enough fuel, that is why it's dying....even with just an ls/vtec setup you should have slightly larger injectors, not to mention it's turbo'd you should atleast have 450cc injectors and you also need a chipped ecu and a tune.
how come it was running good for 2 day with no problem and i was goin to tune it after my afcneocame in but it dead b4 that so u think i should get bigger injections? that it ?
are you sure it was running "good"? you were probably running out of fuel and detonating if you were beating on it, are you sure you didn't cause engine damage and that's why it barely runs? maybe to a compression test, tell us what numbers you come up with.
hondagirl86
25
10-07-2013 03:49 AM
cheggie
03-10-2011 10:19 PM
