Pistons and rings
Pistons and rings
i just recently picked up an ls swap just for the bottom end and the piston rings need replaced and it needs honed out...but i dont wanna run stock pistons if i gotta do all this....and i plan on boosting in the future...any ideas on name brand pistons? holla at me...2000 Civic SI
Re: Pistons and rings (SIBlue00)
well, i don't know if this is exactly holla ering at you but http://jgenginedynamics.com/Links%20main.html check them out. You know what comp. ratio you're going with?
If you plan on boosting, go with dish topped pistons with a moderate bore, like 0.020" over. That way, you can handle more boost with higher compression. Don't go any lower than 9.5:1 cr. It will take forever to reach boost pressures.Depending on how much cfm your turbo will yield, you may even want to shoot for higher compression.
If this were my build, I'd also go ahead and get some forged rods. Honda rods aren't meant to handle high horsepower from forced induction.
djking
08-14-2010 07:44 PM
