are 96-00 civic ex motors the same?
I have a 99ex I bought that needs a motor I found someone with a 96 motor will this swap right in.
sorry if this has already been answered but I tried searching and nothing with a real answer came up
Thanks
Thanks
Re: (IanB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IanB »</TD></TR><TR><TD CLASS="quote">The only difference is the '96-'98 would be OBD2a and the '99-'00 is OBD2b, otherwise they are all D16Y8's in the EX's.</TD></TR></TABLE>
thanks for the responses guys, and I am not the one putting it in my friend will be installing it for me. is there anything that will be effected by the fact that one is obd2a and one is obd2b?
Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">If you use the wiring harness from the 96-97 you should be good, the 98-99 may be close i dont know though.</TD></TR></TABLE>
does anyone know for sure I am buying the motor to put into the car so I can sell it, and I cant have any check engine lights on thanks again
Re: (DTA-Zombie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTA-Zombie »</TD></TR><TR><TD CLASS="quote">obd2a vs b - distributor plug different - swap distributors or use the other harness. Everything bolts up and plugs up the exact same motor. </TD></TR></TABLE>
Seagull Management
Re: (IanB)
Almost, the intake manifolds are different between the automatic and manual versions. Also '99 - '00 use have some air injection stuff on the intake manifold that the '96 - '98s don't have.
jerryscherry
06-06-2011 01:38 PM
97_hatch
07-06-2006 09:46 PM
