HELP with this fuel issue!! :(
Old Nov 26, 2014 | 07:15 AM
jasonlunaa's Avatar
Default HELP with this fuel issue!! :(
Hello guys! I had this issue since I bought the car but I need to get it fix! Running out of gas is not fun!!!! Okay so I wanted to figure out why my fuel gauge is stuck on E! its not the cluster thats for sure i try my buddy cluster and the meter gauge quickly drop to E, on his cluster he had half a tank! So I figure it could be the fuel gauge receiver? But I took it out you check but I doubt it could be that since it looks new like it has been replaced but i also notice that the cables connectors look burn and had stuff inside them , I figure it could be the cables I'm not exactly sure more likely it is! Idk what to do can I replace the cables with aftermarket or something? If so any links or videos on how to do that or add a aftermarket fuel gauge any help would be the best please!!!!
Running out of gas isn't fun at al!!!! Since I have a fuel pump that uses more gas I need to get this fix!
Old Nov 26, 2014 | 07:22 AM
hondaOchibi7's Avatar
Default Re: HELP with this fuel issue!! :(
Always start with checking Fuses. From there I would check the Sender. Good Luck!
94_civic_dx
Nov 12, 2012 07:30 PM
35r'DHyBriD
12
Jan 3, 2010 01:47 AM
JDM_Spec_SI-R
Sep 20, 2006 05:53 PM
fubulous
Apr 22, 2004 05:56 AM
Rhythm Racer
Dec 21, 2003 07:39 PM
