94 civic loose feeling shifter
Hey i have a 94 with a b series swap. It has alot of slack on my shifter when i move it side to side. So i decided to get the engergy suspension shifter stabalizer bushing. I just replaced that today, and it still has a good amount of slack when i move the shifter side to side. What could it be? What should I replace to fix that slack? Thank you for your time.
Re: 94 civic loose feeling shifter
Have you tried checking the roll pin AKA "bi tch pin" that holds the shift linkage to the transmission? If anything besides the roll pin is used, it will feel extremely sloppy.
it could be the shifter it self were it bolts to the shfitlinkage.... the lil sleeve that the bolts goes threw has o-rings and they get messed up and couse slack
ot the shitlinkage were it has the movable joints by the bitch pin maybe messed up
Yea i think it might be that. When i was movin the linkage that is connected to the shifter it seem that the slack is from that. Do any1 havce a diagram of it? dunno what it exactly looks like.
there is not much we can help you with its one of those things you just need to get under the car and look for loose bolts or bad bushings. When under the car try to move the linkage around and look for the play.
06-17-2005 08:00 AM
