'92 lx, hesitation, sputtering until 4k rpms, rough idle etc..
1992
Lx sedan
D15b7
Manual transmission
All stock
No check engine light's
New plugs
New plug wires
New cap & rotor button
I turn the car on, it idles around 2100rpm's and eventually after warming up it drops to about 1200-1300rpm's. It has a horrible rough idle, it seems lumpy, powerless and hesitates when driving up until about 4krpm's then seems better. Sometimes if I floor it white smokes comes out of the exhaust but nothing else. It reminds me if you were to swap the plug wires out of order and try to drive it.. although the firing order is correct.
I'm uploading a vid and when it is done I'll link it on here.
Lx sedan
D15b7
Manual transmission
All stock
New plugs
New plug wires
Re: '92 lx, hesitation, sputtering until 4k rpms, rough idle etc..
Also:
TPS
IACV
IAT
MAP
clips are all plugged in to the correct sensors. It throws a code if I swap/remove them etc.
TPS
IACV
IAT
MAP
Look at what I've attached, please READ it thoroughly. It's a PDF file for troubleshooting. Sounds like an Idle Control Valve issue. I'll be waiting on the video. Let us know your results. Good Luck.
Sorry the vid wasn't so great, can not hear the erratic idling or anything.
I'll check out the .pdf you attached as well. Timing is dead on, firing order is right, new plugs and etc as mentioned.
Already messed with the iacv and nothing has changed. Might try and bleed the coolant system? besides this I'm stumped!
ArchAngel Sabastian
09-11-2002 09:29 PM
