my 92 eg si just started idling from 1 rpm and 1 1/4 rpm. help?
MY 92 SI EG HAS A 1ST GEN B16 SWAP AND IT JUST STRTED IDLING AND IM NOT SURE WHAT IT IS. i TRIED 3 DIFFERENT THROTTLE BODIES BUT I DON'T KNOW IF IT COULD BE THE WIRING OR MY VACUMES TO THE INTAKE MANIFOLD.aNYONE KNOW ABOUT THIS?
Re: my 92 eg si just started idling from 1 rpm and 1 1/4 rpm. help? (aser1z)
It might also be your TPS. Unless you used new ones when you swapped out your throttle body. I had the same problem and that fixed it.
Re: my 92 eg si just started idling from 1 rpm and 1 1/4 rpm. help? (mikey123)
Yeah i will replace the vacume lines and check my canister.Ill check my tps and see what i can do.thanks.
Also it could be your IACV also known as Idle air control valve they tend to stick sometimes.
Re: my 92 eg si just started idling from 1 rpm and 1 1/4 rpm. help? (EG-B20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-B20vtec »</TD></TR><TR><TD CLASS="quote">Also it could be your IACV also known as Idle air control valve they tend to stick sometimes. </TD></TR></TABLE>
i agree on this.
i agree on this.
Re: my 92 eg si just started idling from 1 rpm and 1 1/4 rpm. help? (lilvietdoode4o8)
are you running a mirco machine? cuz i cant think of any car that idles at 1- 1 1/4 RPM
edit why dont you check your vacum lines for leaks before you ask honda-tech if you have a vacum leak.
ostrichattacker
10-24-2011 07:37 AM
