92 Civic SiR with B16A engine - jerks
Old 07-29-2014, 05:06 PM
dingbaEG6's Avatar
Default 92 Civic SiR with B16A engine - jerks
At a certain speed my car jerks (around 30-40 km/h) and I can feel it the most in the morning. I always warm up my vehicle before driving it. Please help!! Thanks!
Old 07-29-2014, 05:10 PM
shotoutacc0rd's Avatar
Default Re: Car jerks
you need to tell us about your car, though. 5th generation or 6th generation? Which trim level? Any modifications? Mileage?
Last edited by Former User; 08-01-2014 at 03:39 PM. Reason: Text deleted - knock it off
Old 07-29-2014, 05:12 PM
dingbaEG6's Avatar
Lol!
Its a 92 Civic SiR with B16A engine (118K km). Did some tune up (except the fuel filter and PCV's) and timing belt and water pump change recently. Car is stock except for the aftermarket Air filter.
Old 07-29-2014, 05:14 PM
The Grumpiest
grumblemarc's Avatar
Not enough info.
At the very least you need to give vehicle info. When was the last time you did a tuneup?
And be careful who you listen to. There are a lot of people on this forum giving advice that can't even perform basic maintenance on their own vehicle or identify parts of it.
Old 07-29-2014, 05:16 PM
I never narc'd on nobody!
NotARaCist's Avatar
Read the rules sticky, then try again.
Old 07-29-2014, 05:21 PM
dingbaEG6's Avatar
Originally Posted by grumblemarc
Not enough info.
Last tune up was about 2 months ago (around 115k km, right now its 118k km)
Old 07-29-2014, 05:26 PM
cap, rotor, plugs, wires? Fuel filter? Air filter?
sorry didnt see the edit.
Old 07-29-2014, 05:33 PM
dingbaEG6's Avatar
I'm gonna assume we're talking about a 6th Gen y7 vehicle?
Vehicle info i posted above. Replace cap, rotor, plugs and wires except fuel filter (can't find the fuse) and air filter which is aftermarket.
Old 07-29-2014, 10:34 PM
94CivicHatchGSR's Avatar
Lol!
So it just started doing it?
Old 07-30-2014, 05:23 AM
NerfGunner420's Avatar
like it was said. not enough info. to little info. when did it start etc. come on man get in the game and follow the ball stop space dreaming
Old 07-30-2014, 06:36 PM
dingbaEG6's Avatar
Actually I forgot went it really started, but probably a month ago... Ohh I remember after I change the Speed Sensor which is a month ago.
Old 07-30-2014, 07:14 PM
I cant imagine how a speed sensor would cause this. Maybe you should try exchanging it anyway?
Old 07-31-2014, 02:32 AM
slimx's Avatar
There are so many possibilities, I find a video best.. take one, youtube it and post it here?
While you're pressing the gas,
Is it jerking back and forth, or does it just feel like it's cutting out like a rev limiter? (this is often caused by bad plugs, spark plugs, and sometimes the distributor cap having a crack/leak.)
If it's jerking back and forth it's more likely fuel related, so we're talking fuel pump, injectors etc.
Does the car turn to one side when it jerks? try letting go of the steering wheel and check, could be a lose arm at the bottom even.
Old 07-31-2014, 03:19 PM
dingbaEG6's Avatar
Funny thing today. It was raining here and didn't feel that jerking.. more to follow..
Old 08-01-2014, 03:32 PM
props_honda85's Avatar
My eh2 with a b16 had same issue. It was fuel, cleaned my injectors and then found wiring issues with fuel pump. check everything and write down what you've done & when and keep with your Chilton/Haynes, save time researching the same damn thing over & over
Old 08-01-2014, 10:19 PM
Miguel613ekb18c's Avatar
Default Re: 92 Civic SiR with B16A engine - jerks
Misfire can cause jerks so can bad sensors, tps,map,iat, big enough intake leak
Old 08-02-2014, 07:02 AM
austinkli's Avatar
Sounds most likely like a misfire OP although a video would be extremely helpful. Additionally, if you turn on extra electrical things like lights, AC, windshield wipers, etc, does this get better or worse?
basedmark
16
02-05-2012 08:38 AM
KMSol
10-09-2010 09:01 PM
HU MAN CHU
21
06-21-2006 11:48 AM
EkCivicRunner
05-15-2006 12:34 PM
k193sup
05-13-2002 08:45 AM
Quick Reply: 92 Civic SiR with B16A engine - jerks
