1st gen b16
Old 12-16-2003, 11:38 AM
eG_6ix's Avatar
Default 1st gen b16
will this fit in my eg w/ stock mounts or will i need a hasport kit, i ran search found nothing of use.
tia
Old 12-16-2003, 11:46 AM
2000blackgsr's Avatar
Default Re: 1st gen b16 (eG_6ix)
You'll also need the hydro to cable kit. This outlines the swap.
http://www.hasport.com/Tech/In...s.htm
Old 12-16-2003, 11:59 AM
Risky Business
BauleyCivic's Avatar
Default Re: 1st gen b16 (96coupe)
just do the SIR-II complete swap. Steve at HMO has it on sale for 2250.
http://www.hmotorsonline.com
Old 12-16-2003, 12:01 PM
New User
976's Avatar
Default Re: 1st gen b16 (BauleyCivic)
To answer the question, yes you need a hasport mount kit. I would go Sir II as suggested...
Old 12-16-2003, 12:51 PM
crxste's Avatar
Default Re: 1st gen b16 (976)
If you have a hydro tranny, where do the other mounts differ from teh EF8's?
Old 12-16-2003, 12:54 PM
Risky Business
Default Re: 1st gen b16 (crxste)
the jdm crx Sir has a different front end setup than basically every other civic/crx from 88-00. To put the jdm b16a 1st gen into a usdm civic...whether it be EF, EG, EK you need a mount kit.
Old 12-16-2003, 01:04 PM
function83's Avatar
if he uses a hydro tranny, he still needs to change the driver side bracket and mount to 94-01 integra. also the rear tranny bracket from 94-01 teg.
not to forget also the ac bracket with torque mount, and front tranny mount.
94-01 teg.
either re-use his civic harness modified or a 94-01 teg harness.
tRex99
01-29-2005 03:23 PM
Josh717
12-26-2003 04:41 AM
wm5holla
05-23-2003 06:40 PM
irev210
02-03-2003 11:44 AM
paulzy
04-24-2001 12:54 PM
Quick Reply: 1st gen b16
