1996 Civic timing question
Old 02-03-2014, 03:23 PM
raider1qaz's Avatar
Icon3 1996 Civic timing question
Well when i time my car with the timing marks i do the cam first then the crank and i put the pointer on the red mark but when i put the belt on and put the cam the right way the timing on the bottom is way off,is this suppose to happen??? the cam says "up" is facing 12oclock but on the bottom pointer the mark is like a inch to the right(red mark on picture is where the pointer is pointing to)
Old 02-03-2014, 03:25 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: 1996 Civic timing question
The "pointer" is supposed to go to the white mark when installing a timing belt. The red mark is your setting your ignition timing.
Old 02-03-2014, 03:29 PM
raider1qaz's Avatar
it is?so when i time the belt i use the white mark/?
Old 02-03-2014, 03:30 PM
raider1qaz's Avatar
when the "UP" is at 12oclock the pointer is suppose to be pointing at the white markl?
Old 02-03-2014, 04:12 PM
NotARaCist's Avatar
Yes, when you set mechanical timing, it is. When you set ignition timing (motor warm and running, with a timing light, by twisting the distributor, you use the red mark.
Old 02-03-2014, 06:22 PM
raider1qaz's Avatar
thank you very much
Old 02-03-2014, 07:45 PM
kwae's Avatar
Awesome timing belt video
KeithsDAteg
11-29-2009 05:32 PM
D16SohcVtec
04-10-2009 11:35 PM
supabang
08-03-2007 10:54 PM
getdowndoyou
03-14-2007 08:14 PM
joestud
07-09-2002 11:49 PM
Quick Reply: 1996 Civic timing question
