00 civic si header install its not fiting we dont know drop it from the bottm or top?
Re: 00 civic si header install its not fiting we dont know drop it from the bottm or top? (gulftires
What do you mean? If you mean what I think you do, install it from the bottom of the car. Slide the top (part that mates with the engine) in up through the bottom.
Hope this helps
Hope this helps
i done once and i put it in through the bottom. it seems too hard from the top
What header are you installing? If it's a 2 piece you can install the 4-2 portion from the top then go underneath and bolt up the 2-1. If it's a 1 piece then jack the car up, support it with jackstands, take off the splash guards to make it even easier, and slide it up. Then go back out and bolt it on. helps if there's two people so you don't have to go back and fourth. good luck
i usually just go from underneath, but slide the header in at an angle and then straighten it out
You have to go from under the car. Put it in on an angle and work it up, its a little tricky but you can get it. I've taken mine off and on by myself a bunch of times. Just watch for the clutch master cyl and you'll be
madlion
10-11-2004 04:07 PM
