[FAQ] SOHC upgrades *REVISED* It's long and is a work in progress.
Old 05-28-2009, 02:40 PM
  #576
famou55TAR's Avatar
Default Re: [FAQ] SOHC upgrades *REVISED* It's long and is a work in progress.
Great write up. i was debating if i should stick with my sohc or upgrade to a b series. awsome.
Old 09-06-2009, 01:34 AM
  #577
23LX23's Avatar
great read... but for a noob like me, its still kind of hard to understand lol... any other easy bolt ons to increase power that wont require other side **** to go along with it?
Old 12-18-2009, 12:58 PM
  #578
e1ght4vii's Avatar
Icon3 Re: EDITED 7/19/05
Engine: Well, where the hell do we start? The motor mounts all have gaps in them. jimfab.com has inexpensive polyurethane mounts. And the mounts that they don’t make you can go to hasport.com and get the rest. Okay, now that you got that sucker still, lets increase some power. On a naturally aspirated engine there are # things you can do.
1. Increase the compression
2. Increase the displacement by bore (size of pistons) or stroke (crank)
3. Add more aggressive cams or cam for the SOHC.
One way to up the compression is to mill the head. It is very important for you to not remove more than .03. If you do, you risk timing issues because the timing belt is going to have slack and you will risk jumping teeth on either the cam gear or the crank and your timing will get screwed up. You can also get thinner head gaskets, the Y8 is cheap and is the thinnest metal OEM head gasket that you can get. Now that we have covered some inexpensive increases, let us move on to pistons. The 1988-1989 D16A1 Engine came with some really high dome pistons, they will increase your compression ratio as follows:
d16a1 pistons (stock bore) in the following with a y8/z6 metal head gasket (no mill):
d16a6= 11.0: 1 compression
d16z6= 12.0: 1 compression
d16y8= 12.6: 1 compression
installed the d16a1 pistons in2 my crx si block for the mini me set up and wen i set the d16z6 head down on it without head bolts and turn the pistons they hit the valves do i need to get the pistons machined so the valves dont hit or wen put the head bolts in and timing belt on and have them both on TDC will they not hit? just being procautious b4 i get my engine 2gether try 2 start it and bend some valves
Old 12-18-2009, 06:05 PM
  #579
kallar68's Avatar
great post; good read
Old 03-31-2010, 01:24 AM
  #580
shyguy4no1's Avatar
Originally Posted by yvelt
My Civic 2000 DX has a stock automatic transmission D16Y7 engine.
I've only changed the OEM intake to a AEM SRI setup and changed the OEM exhaust A and B tubes to an APEXi World Sport 2 Catback Exhaust system
Right now, i've bought a D16Y8 Intake Manifold (IM) and an automatic throttle body from an 2000 Civic EX.
Was wondering if I were to swap out my D16Y7 OEM IM, for the D16Y8 IM and throttle, would it pass California SMOG test? Would I need an engine tuning? Idle?, etc.
If it's okie, i'll be looking at getting a Mishimoto Intake system for the D16Y8 IM.
Looking forward to everyone's experience and feedback
sadly CARB says no. It is illegal for an intake from one year/ engine type to be put on another year/ engine type. (sucks I know.)
Old 03-31-2010, 01:27 AM
  #581
shyguy4no1's Avatar
I got a question... will the edelbrock performer x intake manifold fit onto a d16a6? and will it pass CARB for a d16a6?
Old 04-14-2011, 04:27 PM
  #582
UCNTCME's Avatar
can i bring this back? ive been reading every page for that past couple days everytime i get a chance!
i want to put a mini me together. ill check this dAily to see if i get spade or any of those other gurus on to help me out! D-series cus I can!
Old 05-02-2011, 09:17 PM
  #583
Azintel1's Avatar
Thanks for all the info I am just getting into Hondas and it was super helpful to read all this information.
Old 05-18-2011, 06:09 PM
  #584
JLoCiv19's Avatar
Thanks man, this gave me some nice ideas for my D-series build.
Old 12-17-2011, 10:37 AM
  #585
Mattbrain's Avatar
This is an awesome post. Been trying to find something like this for a hot minute
Old 12-17-2011, 10:47 AM
  #586
CdLem1's Avatar
brilliant post its very detailed and gives me more ideas on how to upgrade
Old 03-24-2013, 10:14 PM
  #587
evo8man's Avatar
Nice write up.
Old 04-11-2013, 04:05 PM
  #588
dseriessquad's Avatar
im new to hondas. just bought a 2000 ex with skunk2 lowering springs, yonaka catback, high flow cat, short ram, 255 walbro fuel pump, short shifter and energy shift bushings. i want to keep good gas mileage but more power wouldnt hurt. do i keep modding or leave it as is?
Old 05-13-2013, 08:10 AM
  #589
EFSedan#6's Avatar
Such a great post.
Old 02-06-2014, 11:30 AM
  #590
jaycorolla's Avatar
WOW..... this is a long thread and you know what might as well see if we can still keep it going, the info is great from page one and this is so interesting to see how things have evolved over the past 10 years, seeing trends come and go to how parts evolved and what people thinks about the love D-series motor. i too love my d-series motor, i have built 3 over the years, even still while now having a b18c ( with work done to it) there is nothing like the feel of the pull of a single cam.
im in the progress of building a d15b7/z6 mini high comp. supercharged motor, i plan to be using eagle rods built for the d15b7, im seaching now for pistons but i looks like ill be getting a set made for the d15 motor, and im going to use a built z6 head with port n polish with springs, retainers, and valves all upgraded, i think ill be using a supertec setup with a skunk2 stage 1 or 2 tuner series cam. the compression ratio goal will be 11:1 while running a Rotex supercharger w/FMI to help lower intake temps charge.
i know the high comp supercharged motor is debatable but i plan on building up to this setup while a few of us are going to use the car in getting our licenses for racing within the SCCA organization. So while we do our required classes and races to gain our needed qualifications to be able to race in all events, the car will also be in the process of getting upgraded as the skill level increases.
In theory as we learn the car and skill increases the car will then be upgraded to meet the needs of the required events.
so i plan to first build the motor as an high compression all motor setup with the h-beam rods and high comp pistons (which it is look like they will be a custom set) and built Z6 head with a good cam the will work all around in na or boosted applications.
then as things progress then adding a Rotex supercharger w/FMI setup so it will be capable for tack running purposes or drag racing, or time attack event. bascially the end goal is to have the car finish as a fuly build d-series motor but being of a d15b7 setup which i havent really seen around. the whp goal is going to be in the 300-350 range for track and for drag maybe more.... idk not there yet.
so sorry this is long winded but let this post revive and it is truly a great info page for the d-series motor. so Thanks Spade.... you started a legendary posting!!!!!
Old 04-07-2014, 07:43 PM
  #591
j3wman's Avatar
This thread is 12 years old, It is literally older than my girlfriend's pubescent little brother. If someone compiled this into a book I would buy it.
Old 05-18-2014, 05:45 PM
  #592
Spade's Avatar
Oh look this thing's still alive. I'm still rockin' the SOHC, but it's boosted now.
It's amazing how much has changed over the years, especially the availability of the D and how it's dropped off.
Anyone dyno one of the higher final drives but leave the dyno computer still set to stock? I'm really curious what amount of "horsepower" the final drives add.
Old 05-18-2014, 07:01 PM
  #593
nub
nub's Avatar
The final drive doesn't change the engines power number. The engine makes what the engine makes regardless of gear ratio.
Old 05-19-2014, 12:01 AM
  #594
Nave43's Avatar
If this isn't sticky'd it should be. Great read, great ideas, all around good stuff for any D-Series owner. Can anyone update this to include the JDM D16A SOHC VTEC as well?
Old 10-21-2016, 04:54 AM
  #595
BoRiCuA's Avatar
Back from the Dead, Tons of info, props to Spade for a great thread. Where is everyone that actually built something?
Old 10-23-2016, 05:23 AM
  #596
BoRiCuA's Avatar
1st of all let me start by saying, Thank you. That 24-page post is great and it has answered most of my questions, which is why i rather go to the man himself. I have a 1991 crx si which i am restoring. I currently have the Oem d16a6 engine and the d16z6. I plan on using the z6.
Info so far that I've gathered for a mild build say 130hp
D16z6
Block= p29 w/ 1.5mm Hg @ 11:3cr ? or pm6 w/ .10 mil from the head with stock 3 layer Hg @ 10:2cr ? what would you recommend?
Head = zex #59300 cam? Do I have to upgrade valvetrain? (Arp head studs and Cam gear i already have)
IM= skunk2 or Elderbrock or just stock what tb? Injectors i heard preludes have 240cc and can be easily modified to fit?
Ecu currently running stock p28, should i get a chip,s200 or chrome.
Other stuff:
12lb flywheel
Aem Cai
dc headers w/ test pipe and 5zigen exhaust 2.5
b-series v-tec fuel pump?
Please elaborate on this build to come, i would appreciate honesty as i don't waste my hard earned money.
slide inside
06-30-2010 07:38 AM
JDM_WHR
01-04-2010 03:02 PM
bbhockey19
17
07-25-2006 02:12 PM
lxaccord51oxl
02-19-2006 10:47 AM
Beach Accord
07-09-2002 12:00 PM
Quick Reply: [FAQ] SOHC upgrades *REVISED* It's long and is a work in progress.
