Automatic transmission filter
I have a 2008 Civic LX, which has an in-line automatic transmission filter. The manufacturer claims it is a "life-time" filter, but debate rages over that claim. One YouTube video showed a dissection of this filter at about 100K miles - it appeared sedimented up and had fragments imbedded in the filter material. My vehicle has 180K miles on it and has the original filter - I suspect it may be shot. It is difficult to access, as it is tucked tightly in under the air box. The rear clamps look nearly inaccessible - some claim they have to be accessed from beneath the vehicle. Anyone have any opinions on the theory of the "lifetime" filter? As far as I know, no filter is so durable as to never have to be replaced.
once you pull the air cleaner assembly it becomes possible to remove it, not too hard, but you will want to buy the two hoses that attach to it...once you start moving the filter those lines will kink up when you try to put the old ones back on, unless you replace the hoses with new one
I guess it boils down to a matter of opinion. Honda has their rationale for saying it is "life-time", which may be based on their criteria for the transmission life. Some say it was added because Honda had trouble with the Civic transmissions and threw the filter in-line as a precautionary adjustment. No one seems to know what the 'trouble-signs' (or issues) might be associated with a plugged filter, or at least none that I could find. I figure changing it out at 180K miles is a prudent service procedure, as it won't have to be done again for a long period of time.
I have a pretty good selection of tools, but some jobs require a specialty tool that I didn't anticipate, even after researching the job. That axiom is completely correct though.
tempsohc
356
Apr 8, 2010 02:35 PM
