code 41
Old Jun 20, 2006 | 08:11 AM
MiMiK's Avatar
Default code 41
ok, so here's the deal. the car is a 96 civic ex converted to obd1(running a chipped P28), cat removed, secondary o2 sensor removed. the check engine light comes on a few seconds after start-up... so i change the primary o2 sensor(the one that goes on the header), reset the ecu, and i still get a check engine light.... i check the code again and it still gives me code 41... is there anything i'm doing wrong???
Old Jun 20, 2006 | 08:25 AM
JDM-97CX's Avatar
Default Re: code 41 (MiMiK)
How did you go about resetting the PCM?
Old Jun 20, 2006 | 08:37 AM
MiMiK's Avatar
disconnecting the negative terminal on the battery for about 10 mins.
Old Jun 20, 2006 | 08:38 AM
JDM-97CX's Avatar
Default Re: (MiMiK)
Did the check engine light come immediately back on?
Old Jun 20, 2006 | 08:40 AM
MiMiK's Avatar
Default Re: (JDM-97CX)
just like it did before. after the motor runs for a couple seconds.
Old Jun 20, 2006 | 08:43 AM
JDM-97CX's Avatar
Default Re: (MiMiK)
Remove your PCM fuse for a few minutes. If that does not get rid of the light it means you have not yet fixed your problem.
Old Jun 20, 2006 | 08:44 AM
MiMiK's Avatar
i'll do that now. thanks.
Old Jun 20, 2006 | 10:13 AM
Relic1's Avatar
pulling the backup fuse, pulling the ECU and removing the negative terminal of the battery are all going to result in the same thing.
resetting the ECU.
Pulling the fuse or negative terminal for anything more than 30 seconds is only a waste of time. UNLESS you have an amp or caps to backup something in the car.
If you're paranoid about it flip on your headlights for a second, they will kill any power left in the car instantly.
If that doesn't solve it you have a problem with the O2 or the wiring to the heater portion of the O2.
Old Jun 20, 2006 | 12:51 PM
MiMiK's Avatar
yeah, it's still on.. i'll be taking it to someone tomorrow..
Old Jun 20, 2006 | 12:56 PM
Wicked-Civic's Avatar
Code 41 is the oxygen sensor. You might need to recheck the harness and the wiring. But If you reset the ecm and it still comes on it's either something in your wiring or it's something in the ecm
Old Jun 20, 2006 | 01:49 PM
MiMiK's Avatar
i have the worst luck with ecm's.. but i check it by using it on my friend's car and it works fine with no cel... so it must be the wiring.. i hate wiring.
Novz
Honda Civic (2001 - 2005)
Apr 22, 2013 03:26 AM
91(si)hatchey
Mar 12, 2007 11:03 AM
h22xcivic
Apr 27, 2006 07:51 PM
n3v3tz
10
Feb 3, 2004 08:46 AM
