Problems with O2 sensor
Old May 23, 2003 | 10:37 AM
General Kills's Avatar
Default Problems with O2 sensor
My cousin has a 90 Accord EX. The check engine light stays on even after they replaced the O2 sensor, which is what the diagnostic test said to replace. Any help would be appreciated.
Old May 23, 2003 | 02:02 PM
iam7head's Avatar
Default Re: Problems with O2 sensor (Tunerdude)
does it throw a code?
Old May 23, 2003 | 05:44 PM
92 ex-r's Avatar
clear the code and then see if it comes back on. I replaced the o2 in my car the light was still on so I cleared the code problem fixed.
Old May 23, 2003 | 06:13 PM
Default Re: Problems with O2 sensor (92 ex-r)
You clear the code by unplugging the negative battery terminal right? They did that and the code is still on.
Old May 24, 2003 | 06:08 PM
92 ex-r's Avatar
THere must something else wrong check for other codes. Behind the right kick panel there is a little plug 2 prong. Use a jumper wire and put in the terimals count the flashes from the check engine light . I'll get the code sheet from work so let me know. By the way my car is a 92 ex-r and 2 clear the codes I had 2 pull the back-up radio fuse for 10 secs. Under the hood in the fuse box 7.5 amp.
Old May 24, 2003 | 07:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tunerdude &raquo;</TD></TR><TR><TD CLASS="quote">My cousin has a 90 Accord EX. The check engine light stays on even after they replaced the O2 sensor, which is what the diagnostic test said to replace. Any help would be appreciated.</TD></TR></TABLE>
What's the code?
xTomei
Jun 29, 2010 09:27 AM
EK9_GRL
Oct 8, 2007 12:03 PM
914b16
Sep 26, 2007 08:22 AM
slim689
Apr 19, 2007 10:55 AM
vuthe32
Sep 23, 2004 06:10 PM
