engine cleaner
Old Dec 20, 2002 | 08:43 PM
ratherbewalking's Avatar
Default engine cleaner
i did a search and found alot of clean engine bays, and was wondering what you all use to clean them, as well as the engine.
Old Dec 25, 2002 | 08:37 PM
kepani's Avatar
Default Re: engine cleaner (ratherbewalking)
use simple green. open your hood and cover your distributor, fuse box, intake (and anything electrical). spray a generous amount of simple green over the entire engine bay. spray more on the really dirty areas. if you need to, use a soft brush or towel to rub the stained areas. then hose down with water (avoid spraying with high pressure near the areas you covered). after that, start the car and let the heat evaporate the water. simple green!
Old Dec 25, 2002 | 09:37 PM
weakGOODJunKieS.com's Avatar
Default Re: engine cleaner (kepani)
last time i did that, it fried my alternator.
Old Dec 26, 2002 | 12:11 AM
MTK Kommander's Avatar
Default Re: engine cleaner (cnguyen32)
go to autozone.. get some stuff called "Foamy Engine Brite" cover your electrical stuff.. spray the foam on EVERYTHING.. wait about 10-15 mins.. MAKE SURE THE ENGINE IS COOL.. then just rinse with the hose..u dont even need high pressure. the dirt and grease will just slide off..
here is an example..
Before
After
the engine bay is all cluttered, but you can tell there is a big difference in cleanliness.. thats just Foamy Engine Brite and a high pressure washer..
[Modified by MTK Kommander, 1:12 AM 12/26/2002]
2000SICVC
Paint and Body
14
Jan 7, 2012 01:40 PM
mynameizstitch
Jul 3, 2009 04:15 PM
megalomaniac001
Honda S2000
Apr 2, 2008 11:40 AM
K-Spec
Jan 30, 2005 01:43 PM
xiLLtegRax
Sep 15, 2004 08:12 PM
