Changing driverside headlight
Re: Changing driverside headlight (Tokyosmash!)
if you pull the inner fender liner loose at the front bumper edge you will see the bulb right there u only will need to move it enough to get your hand in. you shouldnt have to take any clips or bolts out good luck!!!!!!!!!!!!!!!!!!!!!!!!!11
Re: Changing driverside headlight (JDM_Acccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josephcitr »</TD></TR><TR><TD CLASS="quote">if you pull the inner fender liner loose at the front bumper edge you will see the bulb right there u only will need to move it enough to get your hand in. you shouldnt have to take any clips or bolts out good luck!!!!!!!!!!!!!!!!!!!!!!!!!11
good tip
good tip
breathinez
09-17-2004 08:26 AM
