Changing a headlight
Old Jul 2, 2008 | 07:44 AM
dsmgurrl's Avatar
Default Changing a headlight
I need to change the driverside headlight in my 95 Integra. Can I do this without removing the bumper? Is there some trick I'm not seeing? Thanks!
Old Jul 2, 2008 | 08:02 AM
all-mtr-teg's Avatar
Default Re: Changing a headlight (dsmgurrl)
Get yourself a manual, that will be the best investment you can get for your car.
Are you just changing the bulb or the entire headlight assembly?
Old Jul 2, 2008 | 08:30 AM
dsmgurrl's Avatar
Default Re: Changing a headlight (all-mtr-teg)
I actually have the Haines manual...I forgot about that. I'm changing the whole headlight. Its completely dead from moisture.
Old Jul 2, 2008 | 08:45 AM
lmike6453's Avatar
when I took mine out I took off the bumper. I think you have to.
Old Jul 2, 2008 | 09:02 AM
hatchling37's Avatar
Default Re: (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">I think you have to.</TD></TR></TABLE>You most definitely do. Remove the screw for the corner lamps and pull the housing out of the bumper cover and unplug the lights. Then, there are about ten bolts holding the top of the bumper on, and a half dozen or so on the bottom along with a handful of clips. After they're all removed, the bumper should just slide right off. Then you have only a couple 10mm bolts and the headlight housing should come off. Reverse procedure to install.
dx_rex
Apr 30, 2009 11:05 PM
1.6sohcvtec
14
Aug 4, 2006 02:47 PM
azian21485
May 11, 2004 08:13 AM
LudeyKrus
Jan 22, 2003 05:49 PM
Turbo Powa
Mar 26, 2002 01:16 PM
