Tune Up - When to change Distributor Cap & Rotor
#26
Re: Tune Up - When to change Distributor Cap & Rotor
I personally don't like to take off my original equipment to put in the cheap chit they sell us at the damb auto parts store. If the caps electrodes are not worn out....then leave it alone. Double goes for the wires.
If you have a problem with the car then troubleshoot it correctly and you'll discover the true gremlin without having to throw away your money and damb best original parts not needing replacing.
Sometimes u can even just scuff up the electrodes and they will be like new.
Newer stuff is cheaper plastic molding or chitty electrodes....its the modern replacements that only last 30K miles...so think twice before scrapping oem parts for any vehicle. I cant tell u how many times Ive kept the oem part and had a newer part fail shortly after discovering that was not the problem and have had to slap back the original one in. Just ask my shed.
#27
I just hit 261K last week! I was thinking about cleaning my EGR ports with Brake cleaner or something. Also, I heard about Seafoam. Does that stuff work?
#28
If you're going to remove the intake manifold to clean out the ports and you're sure you're going to be cleaning that brake cleaner out really good I guess no big deal, but if you're going to be doing a half hazard job and not pulling the intake manifold off the car to do it right just stick with carb cleaner. Brake cleaner isn't exactly combustible. Seafoam in the intake is really only used when you want to try to get the intake manifold without pulling it.
#29
#30
I have 145k on my 2001 Accord and I never even inspected distributor, car still purrs and I still have the original wires. I replaced my plugs at 120k and cleaned my throttle body and IAG valve at 135K. I will replaced wires, dist, and rotor when the car starts to miss or fails to start. I had a 84' Prelude that never needed a distributor or rotor changed... 25 years.
#31
#32
#33
Old Thread Revival! 96 Honda Accord EX 2.2 VTEC 250k miles on original spark wire cap rotor.
Car is finally a bit hard to cold start, maybe time for a new cap! Probably have to special order from Dealer.
After Cap maybe replace rotor, fuel filter, check spark wire & fuel pump, and then cylinder compression? Am I missing anything?
Car runs fine after it starts BTW. Already had main relay replaced.
#35
Thanks! Yes I forgot to mention the engine recently got a new set of plugs. Had the car since 96' and it probably is still on its original transmission fluid too! Damn near indestructible (knock on wood).
if you haven't done so in a while - change your distributor cap, rotor button, plug wires, and plugs
Black R
04-22-2006 07:02 AM
