Bad distributor?
Old Mar 29, 2003 | 11:16 AM
Kamin's Avatar
Default Bad distributor?
Well im doing a swap for a buddy and its been one giant headache.
we cant get it started, yesterday there was a spark, but a weak one. now there is no spark comming from the dizzy.
pulled the dist, the rotor and connectors in the cap are charred back, that means its toasts right?
im not sure because ive never dealt with a dist. problem before.
[Modified by Kamin, 12:17 PM 3/29/2003]
Old Mar 29, 2003 | 11:49 AM
orange.honda's Avatar
Default Re: Bad distributor? (Kamin)
i would just go ahead and change out those components if there is any question as to their being in good shape. if you are going to change cap and rotor you might as well get new wires and plugs.
when you had spark, was that at the wires, plugs or rotor? i ask bc if it was weak at the plugs then, the coil is probably still good if it was weak at the rotor maybe time to change the coil. you should do an internal resistance test on the coil just to be sure its up to par with the specs. good luck.
Old Mar 29, 2003 | 11:53 AM
civicrtype's Avatar
Default Re: Bad distributor? (orange.honda)
Make sure u check the ground on the theromstat housing. I had the same problem, a little spark then none, and the whole time the ground was loose.
Old Mar 29, 2003 | 11:55 AM
Default Re: Bad distributor? (civicrtype)
yea, that is a good one. bad grounds make **** work shitty.
Old Mar 29, 2003 | 12:24 PM
civicrtype's Avatar
ya check that b4 u go and start buyin parts. That ground is very important cause it provides ground to the Main Relay and also to the ECU.
[Modified by civicrtype, 4:25 PM 3/29/2003]
Old Mar 29, 2003 | 01:33 PM
dphi's Avatar
I had the same problem. Weak spark, changed coil, everything was A-OK. I'm sure you can find somebody with a spare coil laying around somewhere.
Old Mar 29, 2003 | 02:06 PM
Kamin's Avatar
thanks guys
the ground is good, checked it already
and when i had a weak spark it was at the plugs. now there is nothing from the dist.
Old Mar 29, 2003 | 03:23 PM
Quik Chris's Avatar
Kamin--- Typically when the distributor goes bad, you'll get that redish brownish dust that coats the inside of the cap. I have a bunch of distributor parts if you need then, ignitors, coils, magnet pick-ups, spindles, housings.... The bering goes bad in the spindle and causes that red dust to go everywhere. I've had it happen a couple-a-times. Good luck
Edit: Sounds like you should try the $34 cap and rotor treatment first
[Modified by Quik Chris, 5:24 PM 3/29/2003]
Old Mar 31, 2003 | 05:44 AM
sailor's Avatar
Default Re: Bad distributor? (Quik Chris)
wheres the ground on the thermostat housin?
Old Mar 31, 2003 | 07:01 AM
Ya@inlinePRO's Avatar
Default Re: Bad distributor? (sailor)
also check the ignitor itself....
Old Jul 31, 2003 | 12:49 AM
White98LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sailor &raquo;</TD></TR><TR><TD CLASS="quote">wheres the ground on the thermostat housin?</TD></TR></TABLE>
I wanna know too.
Old Jul 31, 2003 | 05:03 AM
civicrtype's Avatar
Default Re: Bad distributor? (White98LS)
on a bseries, look in the area under the throttle body there should be a fat coolant hose going into it. Its almost like ball shaped, there should be a ground there going from your engine harness, it grounds the mainrelay and ecu.
Old Jul 31, 2003 | 07:12 AM
gitwidit's Avatar
Easiest way to test it is to just swap a comparable distributor off of another setup for a second.
Old Jul 31, 2003 | 07:45 AM
White98LS's Avatar
Default Re: Bad distributor? (GITWIDIT)
Sweet thanks guys, I'll definitely check that (was planning on swapping a dist., praying it'll work).
motoxxxman
May 1, 2015 09:00 AM
NOOdS
Feb 13, 2009 02:31 PM
ls19integra95
Apr 15, 2007 11:40 AM
Eclpze97
Jan 2, 2005 02:54 PM
sodacan33
Jun 17, 2004 06:53 PM
