problem fixed
Old Dec 6, 2005 | 05:52 AM
. C h e n l a's Avatar
Default problem fixed
It was a chilly night around 8pm
driving home from school
about 80 Miles away from Richmond
My car on the interstate makes a lil pop noise and starts to sound like a lawn mower
i open the hood and this was hanging out and it was sparking a little bit
(pics from the next morning)
since i don't know much about cars honestly i just figured i needed to take the spark plug out and replace everything that was messed up
so i did and it worked...
(oh and the original spark plug was gone when i opened the hood )
and i have a little dent on my hood now from when the cylinder popped up
anyways heres my daily stock 94 ex
Old Dec 6, 2005 | 06:00 AM
propwdialogue's Avatar
Default Re: problem fixed (Chenla Ou)
Thats craziness, anyone have ideas as to what exactly happened there?
Old Dec 6, 2005 | 06:22 AM
PhantomPhanatic's Avatar
Default Re: problem fixed (propwdialogue)
Loose spark plug and high pressure in the cylinder. *Pop*.....that's hilarious though....I'm supprised the engine didn't stall on only 3 cylinders.....lol......yeah....that would sound like a lawnmower....
Old Dec 6, 2005 | 06:30 AM
jamin's Avatar
Default double check w/torque wrench
i only trust the job if i tighten plugs myself.
a few years ago my daughter had plugs replaced at a gas station. a few weeks later car had vac. leak and i found very loose plug.
also i have never been able to know how tight my plugs are by hand in my mazda-alum head- so i always confirm w/my torque wrench in all my cars now.
Old Dec 6, 2005 | 06:35 AM
maroonaccord2.2's Avatar
Default Re: double check w/torque wrench (jamin)
Torque wrench is the way to go.....I'd figure by now that'd be common sense. But as it turns out, common sense is not so common.
Old Dec 6, 2005 | 09:32 PM
JDM MonopolyMan's Avatar
As stated above, torque wrench is your answer.
btw your car looks really clean, lower it and leave everything else stock and it will be absolutly beautiful!
Old Dec 6, 2005 | 09:57 PM
YeuEmMaiMai's Avatar
at least it didn't dent the hood to the point where you can't fix it when it popped out...good to hear everything is OK
Old Dec 7, 2005 | 05:02 PM
Default Re: (JDM MonopolyMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM MonopolyMan &raquo;</TD></TR><TR><TD CLASS="quote">As stated above, torque wrench is your answer.
btw your car looks really clean, lower it and leave everything else stock and it will be absolutly beautiful!</TD></TR></TABLE>
thanks
any suggestions on what i should get to lower it?
Old Dec 7, 2005 | 05:08 PM
HondaMike17's Avatar
Default Re: (Chenla Ou)
this actually makes me angry, because in my auto class the teacher never torques the spark plugs when he changes/checks them, but i always grab the torque wrench and do it anyways when he walks away, gotta be safe man, expecially with something that important
Old Dec 7, 2005 | 10:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chenla Ou &raquo;</TD></TR><TR><TD CLASS="quote">
thanks
any suggestions on what i should get to lower it?</TD></TR></TABLE>
It all depends on what you want and what you want to do with your car. I personally do auto cross and drive my car daily so i'm going with a medium setup which is a Tein basic coil over dampener.
Old Dec 8, 2005 | 02:14 AM
Default Re: (HondaMike17)
I have never ever used a torque wrench to tighten plugs. I have always put them in finger tight plus 1/4 turn. Never had a problem yet.... and I have owned 7 different cars.
Old Dec 8, 2005 | 05:13 AM
fw190bvi's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">I have never ever used a torque wrench to tighten plugs. I have always put them in finger tight plus 1/4 turn. Never had a problem yet.... and I have owned 7 different cars.</TD></TR></TABLE>
same here.....expletive, ive never personaly used a torque wrench in all of my life
that is weird as hell though...does anybody have an actual explination for what happeneD?
Old Dec 8, 2005 | 05:38 AM
Default Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
that is weird as hell though...does anybody have an actual explination for what happeneD?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomPhanatic &raquo;</TD></TR><TR><TD CLASS="quote">Loose spark plug and high pressure in the cylinder. </TD></TR></TABLE>
Old Dec 8, 2005 | 05:10 PM
HandoEX's Avatar
It all depends on what you want and what you want to do with your car. I personally do auto cross and drive my car daily so i'm going with a medium setup which is a Tein basic coil over dampener. </TD></TR></TABLE>
I rock the same set up and highly recommend it for the $$
Old Dec 8, 2005 | 06:48 PM
SteveoBA8's Avatar
Default Re: (HandoEX)
I never torque spark plugs, its all in the hand, now lugnuts and stuff i always do, just use your head.
Yuyodrift91
Mar 22, 2011 01:01 PM
BuiltCivic99
May 2, 2009 06:49 AM
mrlegoman
Mar 13, 2008 08:22 AM
MonkeyConQueso
Honda Civic (2006 - 2015)
Jan 31, 2007 09:37 AM
ViZ
Mar 28, 2005 06:09 AM
