Bluish smoke coming out of the exhaust..... Help!!!!
My car is burning oil but i'm not sure what the bluish smoke indicates. Does anyone know what the problem could be?
Re: Bluish smoke coming out of the exhaust..... Help!!!! (RedCd5TX)
Bluish Smoke = Burning Oil. Is usually ether your piston rings or valve seals. Do a compression test to check your pistons compression. If the compression isn't even then it could be worn piston rings or cracked/broken piston ring lands. If the compression is good on all cylinders then the leaking is more than likely your valve stem seals.
