compression test.. FUCK!
Old Nov 23, 2003 | 04:05 AM
DANG YO's Avatar
Default compression test.. ****!
my friend that works at honda did a compression check on my car (B16a) lastnight becuz i have blowby and my motor has been sprayed on a LOT. well here are the numbers : cylinder #1 125psi #2 65psi #3 140 #4 140 so the question is since cylinder #2 is so low can it be more then just my rings? the car runs perfect, reallly fast.... but i was thinking, can it be more then just my rings or not since it runs fine doesnt burn oil? any help would be appreciated
Old Nov 23, 2003 | 04:50 AM
DANG YO's Avatar
Default Re: compression test.. ****! (SiR EF8)
anyone?
Old Nov 23, 2003 | 05:05 AM
EX-T's Avatar
You should take another test and put some oil in the combustion chambers to see if it's your valve seals.
Old Nov 23, 2003 | 05:14 AM
DANG YO's Avatar
Default Re: compression test.. ****! (DSeriesBKilla)
will do but if my valve seals where bad wouldnt my car smoke outta the exhaust?
Old Nov 23, 2003 | 05:43 AM
doublejz's Avatar
when my valve seals were bad, it only smoked when I first started it
Old Nov 23, 2003 | 06:02 AM
Patch's Avatar
Default Re: compression test.. ****! (doublejz)
doublejz is right, bad valve seals smoke on startup
bad oil control rings smoke at high rpm
your compression rings are most likely shot
Old Nov 23, 2003 | 06:40 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR EF8 &raquo;</TD></TR><TR><TD CLASS="quote">my friend that works at honda did a compression check on my car (B16a) lastnight becuz i have blowby and my motor has been sprayed on a LOT. well here are the numbers : cylinder #1 125psi #2 65psi #3 140 #4 140 so the question is since cylinder #2 is so low can it be more then just my rings? the car runs perfect, reallly fast.... but i was thinking, can it be more then just my rings or not since it runs fine doesnt burn oil? any help would be appreciated </TD></TR></TABLE>
Ask your freind to do a leakdown test on it. Should tell where it's leaking.
Old Nov 23, 2003 | 12:30 PM
DANG YO's Avatar
Default Re: compression test.. ****! (Chiovnidca)
thanks for all the info, will my car be ok to drive until june? should i use a thicker oil until then? if so what kind? i use 10w-30 right now..
Old Nov 23, 2003 | 01:24 PM
NJIN BUILDR's Avatar
Valve seals won't affect compresssion test.High crankcase pressure (blowby) is usually rings.Your low compression in one cylinder is most likely a bad seat or valve,which is very common with no2.I've seen engines like this run alot of miles after being hurt like this.
Old Nov 23, 2003 | 03:48 PM
DANG YO's Avatar
Default Re: compression test.. ****! (NJIN BUILDR)
how do i fix that?
Old Nov 23, 2003 | 03:51 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR EF8 &raquo;</TD></TR><TR><TD CLASS="quote">Your low compression in one cylinder is most likely a bad seat or valve
how do i fix that?</TD></TR></TABLE>
Would you like to be sure that is what it is?
Old Nov 23, 2003 | 04:02 PM
DANG YO's Avatar
how can i find out for sure what the problem is with cylinder #2?
Old Nov 23, 2003 | 04:05 PM
Patch's Avatar
Like we said earlier, do a leakdown test.
Your compression test already showed that your motor is toast, you know you have to rebuild it. Obviously, with any rebuild, you'd change at least the valve seals and piston rings. Its one of the two, I'd go ahead and rebuild it instead of running around on a busted B16.
Old Nov 23, 2003 | 04:13 PM
DANG YO's Avatar
Default Re: compression test.. ****! (Patch)
the thing is that it doesnt get driven everyday, once or twice a week. i know my compression is low but my motor isnt toast and i dont consider doing pistons rings a rebuild... when i do the piston rings i am gonna replace all the gaskets and timing belt and stuff, i prolly wont do the valve seals unless i HAVE to. the car doesnt smoke, doesnt burn oil and runs perfect, so will it be fine to drive it till june? it wont be driven everyday so...
Old Nov 23, 2003 | 04:39 PM
civicvtec3's Avatar
hey since cyl. 2 is low ya there can be more than rings involve what you need to do now is have a leak down test done so that you can determine wether it is rings, valves, or a whole in the piston. well good luck to you.
Old Nov 23, 2003 | 07:20 PM
lsvtec hatch05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR EF8 &raquo;</TD></TR><TR><TD CLASS="quote">the thing is that it doesnt get driven everyday, once or twice a week. i know my compression is low but my motor isnt toast and i dont consider doing pistons rings a rebuild... when i do the piston rings i am gonna replace all the gaskets and timing belt and stuff, i prolly wont do the valve seals unless i HAVE to. the car doesnt smoke, doesnt burn oil and runs perfect, so will it be fine to drive it till june? it wont be driven everyday so...</TD></TR></TABLE>
it seems that you don't wanna fix the problem, so you might as well just keep driving it till the motor blows
Old Nov 23, 2003 | 08:34 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
so if u are not planning on changing anything, then why even ask or care???
Old Nov 24, 2003 | 04:26 AM
DANG YO's Avatar
Default Re: compression test.. ****! (bruceleeroy)
its not that i dont wanna fix it, i dont have money to fix it, i am just gonna keep driving it until it decides to blow the **** up, then i will order a new b16 long block from hmotorsonline......
red91hatch
May 18, 2008 11:32 AM
iBrandon
Jul 31, 2006 08:03 AM
red teg
Oct 9, 2005 03:33 PM
xlusiveracer
Sep 7, 2005 04:13 PM
Yosshaa
May 23, 2004 11:55 AM
